    3D Truss Models
    1.5k Posts 31 Posters 976.4k Views 30 Watching
    • pbacotP Offline
      Have you thought about multiple plate heights. Often when roofs are this complex, the house will also have multiple plate heights
      • medeekM Offline
        medeek
        Variation in plate heights, pitches, overhangs and even mixing hip and gable (half hip, dutch gable) further complicate the matter. To begin with I need a algorithm to generate the roof planes, then the framing just falls out from there. To create the roof planes I need a fairly robust straight skeleton implementation.
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • medeekM Offline
          medeek
          Version 1.2.6 - 01.18.2016
          • Sill plate option (advanced) enabled for top and bottom bearing floor trusses.
          http://design.medeek.com/resources/images/truss_su55_800.jpg
          3D Warehouse
          (3dwarehouse.sketchup.com)
          Work on the manual is progressing however for those interested the red colored boards in the image are called "ribbon boards". This is fairly typical for floor trusses. The notch purposely left in the truss to accommodate the ribbon board is called the ribbon cut or ribbon notch. Continuous ribbons provide stability for installed trusses, and also provide a solid nailing surface for the edge nailing of floor sheathing. This eliminates the need for larger and more expensive “rimboard” solutions required by dimensional lumber and other engineered wood products. 2x4 lumber is common, but any dimension of 2x lumber can be used for the ribbon board.
          Similar to the complex hip roofs I need to program the floor truss/TJI module so that it can automatically frame out any non-rectangular floor plan. It seems like my goals keep getting more lofty and ambitious as I dig deeper into this, at some point I should reach the end of the rabbit hole.
          design.medeek.com
          • medeekM Offline
            medeek
            Version 1.2.6 - 01.19.2016
            • Added Solid Sawn Floor Joists (metric and imperial)
            • Sill plate and Sheathing options (advanced) enabled for TJI and Solid Sawn floor joists.
            design.medeek.com
              MtnArch
              @medeek said:
              As you can see there is still a tremendous amount of work that can be done here. To that end I've started a KickStarter project which if successful would allow me to devote at least 4-5 months of my undivided attention on the programming of this plugin:
              Just a moment...
              (www.kickstarter.com)
              C'mon everyone ... let's help Nathaniel - I've put my seed money up for him, what about you? This is a pretty amazing plug-in that can only get better and more amazing!
              (and, just for the record, I've already paid (pretty early on) for a permanent license!)
              Thanks, Nathaniel, for undertaking this!
              Highest Regards,
              Alan T. Hendry, RA
              Architect
              • medeekM Offline
                medeek
                I just saw your pledge this morning, thank-you for the serious vote of confidence. I spent a few minutes and updated the KickStarter page to better reflect the current status of the plugin.
                design.medeek.com
                • medeekM Offline
                  medeek
                  In a related note but slightly unrelated I've decided to take a small break from directly programming of the Truss Plugin and apply some effort to the integrated Truss Designer. I've had a number of requests by various parties and individuals to add in plywood gusset plates to the engineering of the Truss Designer, in lieu of standard metal plates (Mitek, Simpson, ITW etc...). This will allow for the design of site fabricated wood gusset connected trusses, something still found in remote agricultural locations. I'm thinking a couple weeks and I will have this programming task complete, at least for the common fink truss, and then put it out there to gauge the response. This new feature will be available from the Truss Plugin when fink trusses are analyzed.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 1.2.7 - 01.26.2016
                    • Added advanced roof options for hip rafter roof (sheathing, fascia).
                    http://design.medeek.com/resources/images/truss_su56_800.jpg
                    3D Warehouse
                    Couldn't resist adding in these options for hip roof since it was mostly there already from the gable roof module.
                    Adding in the roof sheathing was also an excellent check to make sure I had the roof planes correctly modeled. I'm glad to report that it all checks out.
                    At some point I also need to add more properties that tabulate, areas, lineal feet and weights. This information might be useful for engineering and material lists/estimating purposes.
                    Also note that the fascia boards are not angle at the corners, this is to more easily allow for one to manually push-pull these board to increase or decrease their length.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      I've uploaded a test L-Shaped structure with a hip roof:
                      3D Warehouse
                      I've created both hip roof primitives with the plugin, that was the easy part.
                      I then placed a valley rafter with its centerline (top) inline with both roof planes. I think I've got it right. What I am unsure of however is the best way to terminate the framing at the intersection of the valley, lower ridge and flying hip. Once I have a handle on how a carpenter would actually construct that junction I think I can proceed to start work on a secondary roof module for both hip and gable rafter roofs.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Rev. 5 is a slight variation of the previous roofs. I have shifted the secondary roof over by 24" to create a T-shaped building. The question is how to best frame the long and short valleys:
                        3D Warehouse
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          One method of framing this roof configuration is to extend the lower ridge past the joint until it meets the next jack rafter, then the flying hip and valley are miter cut to meet the lower ridge.
                          I've created a version of the model above with this method of framing at the flying hip/valley/ridge joint:
                          http://design.medeek.com/resources/images/truss_su57_800.jpg
                          3D Warehouse
                          What is the thinking on this method of framing this particular configuration?
                          My other concern is the way I have the valley rafter miter cut where it meets the fascia and the corner of the building wall (top plate). Is there a more practical way or better way of making those cuts?
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Compare Rev 2 with Rev 3:
                            http://design.medeek.com/resources/images/truss_su58_800.jpg
                            3D Warehouse
                            This version of Hip Roof 4 has the flying hip extending as a full hip to the exterior wall and then the lower ridge framing into it with the valley rafter framed in last.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              The intersection of the supporting valley rafter, valley rafter and lower ridge I had framed incorrectly. The corrected method is shown below:
                              http://design.medeek.com/resources/images/truss_su59_800.jpg
                              Also note that the segment of the supporting valley rafter between the upper ridge and lower ridge would need to be beveled or "backed" otherwise it clashes with the sheathing. I noticed this when I originally added the supporting valley rafter but confirmed my suspicion when perusing DeWalt's carpentry and framing handbook this morning. I probably should have pulled this book out before beginning this study but it only confirmed everything I had managed to discover myself once I started examining the model.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Now that I've got a gable and hip rafter roof I was thinking about adding in a dutch gable roof, but I'm a little unclear on the best method to support the end rafters. Has anyone ever seen something like this used?
                                http://www.islandcad.com/parts/hip_collar_bracket_612-l.png
                                I've checked all of my carpentry and construction books and there is absolutely no reference material on traditional framing of this type of roof, online is also quite scant, any resources, framing diagrams etc... would be quite helpful.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  This is my first crack at a dutch gable roof framed with rafters:
                                  http://design.medeek.com/resources/images/truss_su60_800.jpg
                                  Without the sheathing:
                                  http://design.medeek.com/resources/images/truss_su61_800.jpg
                                  Please examine the model here:
                                  3D Warehouse
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Dutch Gable Rev. 2:
                                    3D Warehouse
                                    Same as previous except for doubled up common rafters at dutch gable.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Dutch Gable Rev. 3:
                                      Doubled up gable common rafters with the dutch ridge/ledger is sandwiched between them. Found a paper by Larry Haun, Mar. 1995 "Framing a Dutch Roof" that was published in Fine Homebuilding magazine, that describes a very similar method of framing.
                                      http://design.medeek.com/images/misc/DUTCH_GABLE1.jpg
                                      View model here:
                                      3D Warehouse
                                      Disregard the common rafter sizes they are undersized but look at the method of sandwiching the dutch ridge/ledger between the last common rafters. I would probably also install some blocking between the double gable common rafters. I'm also not showing all of the ceiling joists and bird blocking etc...
                                      If the roof gets large enough then one could go to a double ply dutch ridge, or even a deeper LVL member, assuming there is no internal support available from internal walls.
                                      I think I'm now ready to add the dutch gable roof into the plugin.
                                      design.medeek.com
                                      • pbacotP Offline
                                        That looks like a nice way to do it!
                                        • medeekM Offline
                                          medeek
                                          There is more than one way to skin a cat with this stuff but if I'm going to put something out there I want it to conform as best as possible to current construction methods. Some of these details may be above and beyond what is required but this is the stuff that keeps me up a night.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            I've also realized that for hip roofs I need an option to set the depth of the hip rafters since they are often larger members than the common or jack rafters.
                                            Here is the new icon for secondary roofs:
                                            http://design.medeek.com/calculator/sketchup/images/mdkplg_tool_icon24_7.png
                                            This category will contain the following items:
                                            • Gable Roof Minor
                                            • Hip Roof Minor
                                            • Dutch Gable Roof Minor
                                            • Gable Dormer
                                            • Hip Dormer
                                            • Shed Dormer
                                            design.medeek.com
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 75
                                            • 76
                                            • 20 / 76
