    What's Wrong with the Tape Measure Tool
    24 Posts 7 Posters 5.0k Views 7 Watching
    • cottyC Offline
      cotty
      You can toggle the creation with ctrl (see little + sign).
      my SketchUp gallery
        I think the default behavior has always been to create guides. Could you switch off guides with Ctrl in SU5 and have the setting stay?
        • Joe WoodJ Offline
          Joe Wood
          Yeah I was using XP, now it's Win 7. Sounds like that might be the issue?
          I need to read up on microsoft's windows legacy mode now.
          sorry, don't understand- "You can toggle the creation with ctrl (see little + sign)"
          also "Could you switch off guides with Ctrl " could you explain that a bit more Dave??
          Joe Wood
          woodsshop.com/
            Joe, I don't remember when the change occurred but for a long time, by default, the Tape Measure tool creates a guideline. You can toggle the creation off and back on by hitting Ctrl. This can be useful if you just want to take measurements without creating guidelines.
            Did you look in the view menu to see if Guidelines (or Construction Lines) are an option to turn on and off? We're going back so far I don't remember if this was an option in V5 or not.
            • Joe WoodJ Offline
              Joe Wood
              I've looked everywhere for a setting Dave, but,
              when I select the Tape tool and hold ctrl it makes the guide lines, but that doesn't toggle it on / off because if I try again without ctrl, no lines.
              Joe Wood
              woodsshop.com/
                Does the guideline stay when you use Ctrl? In later versions, at least, it's a toggle thing. Press and release to toggle the state. And there's nothing in the View menu related to it? What about in Styles? Was that a thing then?
                • JQLJ Offline
                  JQL
                  View Menu > Guides
                  It's a style dependent visual effect. You can turn their display off in your current style and some styles have it turned off by default so it's not system dependent. Are you using your own style?
                  I imagine you might have created a lot of Guides without knowing. You might delete them in Edit > Delete Guides
                  www.casca.pt
                  Visit us on facebook!
                    Is it the same in SU5?
                    • Joe WoodJ Offline
                      Joe Wood
                      No Ver 5 doesn't have that menu, doesn't have Scenes either, has Pages and there's nothing in there I can change
                      Joe Wood
                      woodsshop.com/
                      • cottyC Offline
                        cotty
                        Why don't you use a more recent version?
                        my SketchUp gallery
                        • JQLJ Offline
                          JQL
                          And does it have styles?
                          www.casca.pt
                          • Joe WoodJ Offline
                            Joe Wood
                            well part of the reason is, 5 is what I'm familiar with, and it does everything I need it to do, but mainly, Ver 5 is back when it was still @Last Software. There weren't that many users back then, I was probably one of only 5-10 other builders in California, active on the forums, using it. I felt almost betrayed when they sold out to google and all of a sudden everyone was using it.
                            but if I was to upgrade, which version should I go for?
                            Joe Wood
                            woodsshop.com/
                              Get current and install SketchUp 2016. You can still download SketchUp 2015 but I don't believe you can get a license for it anymore. and you don't want to go back any further.
                              • JQLJ Offline
                                JQL
                                Are you still using the computer from back then? With win 98! I miss that computer but I miss ZX Spectrum even more!
                                www.casca.pt
                                  I might be wrong but I think Joe is using Win7.
                                  πŸ˜„
                                  • JQLJ Offline
                                    JQL
                                    πŸ˜„ XP wasn't that bad!
                                    www.casca.pt
                                    • Joe WoodJ Offline
                                      Joe Wood
                                      yeah I'm on a blazin hot computer now and win 7, which isn't as much of a change from xp as I feared,
                                      I could live with needing to use the ctrl with tape tool, and stay with ver 5, question, why should I upgrade, 5 does what I need it to. What do I get, better performance? I never use plugins / whatever. Don't need to take my modeling to diff heights.
                                      say, how do I Import all my XP textures to this new machine? Go to Library, copy all the skm into a new folder, send it to the new machine, then Import> skm, and select all the skm files at once?
                                      Joe Wood
                                      woodsshop.com/
                                        Charlie__V
                                        Joe,
                                        Could be a graphics card issue too........might try disabling hardware acceleration under preferences........though I am just guessing that is/was an option in V5.
                                        Charlie
                                        • Joe WoodJ Offline
                                          Joe Wood
                                          no, that didn't help Charlie,
                                          Joe Wood
                                          woodsshop.com/
                                          • bazB Offline
                                            baz
                                            Joe, Did you do as JQL suggested and look under 'Styles/Guides'?
