    [Plugin]RichSection - not working
    7 Posts 3 Posters 962 Views 3 Watching
    • ntxdaveN
      ntxdave
      I just installed the RichSection plugin (which looks very useful - kind of like Skalp) but nothing happens when I click on the icon to create a rich section.
      I am running SU Pro 2015 - 64bit on Windows 10.
      Any suggestions about what may be wrong?
      Press F1...thank me later
        driven
        have you turned it on?
        in SU >> Preferences >> Extensions...
        • ntxdaveN
          ntxdave
          Yes, it is turned on.
          • srxS
            srx
            Here is the reason and the solution http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=55072%26amp;start=360
            Read all the post on the page.
            www.saurus.rs
            • ntxdaveN
              ntxdave
              All I saw was that other people have the same problem I am having. I did not see a solution.
              I installed the plugin, the created a "building" and made it a group. Then I clicked on the button with the + sign but nothing happens.
              • srxS
                srx
                You need to be more patient in reading. You missed this :
                @srx said:
                Today I found out that plugin has time limit. How to continue using it?
                @dimitri972 said:
                I fixed time expired problem. Here it is:
                http://www.mediafire.com/download/brjzmnqzbcv38fp/RichSectionv0.5.8FULLByDimitri.zip
                Author was't answering question for months. I tried to fixing expired issue and fixed. If this isn't wanting thing in this forum, you can delete my post. I don't know forum rules.
                www.saurus.rs
                • ntxdaveN
                  ntxdave
                  I did see the link but did not understand that is was a fix for the plugin. The fix needs to be made to the version that is in the Plugin Store in SketchUcation (which is where I got the plugin). This means that everyone who downloads if from SketchUcation is getting a version that does not work. According to the info on the SketchUcation web site, it was updated 03-01 of 2015.
                  There also is no mention of licensing, time out period, or cost for the plugin. Just trying to clarify so that others do not have the same problem although I saw that it has been downloaded over 12000 times. I would like some clarification on what is going on.
