πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Sketchup16 Freezes after save/save as..command is clicked
4 Posts 3 Posters 5.5k Views
    art92
    Grettings,
    Recently, (1/8/2016)
    SketchUp began not responding to save or save as or import/export commands.
    It simply freezes right after clicking on the file save as...etc.
    The top bar where tools are generally shown goes to a pale white color, which may be normal...
    however no "select file location" to save into comes up. it simply stays in a frozen state! 😠
    I cannot even close the application, I have to use the task manager to do so... and it doesn't read that sketchup is "not responding". πŸ˜’
    I've updated my graphics drivers and re-installed SketchUp and still no solution.
    If anyone has experienced this error before please comment, any possible solution would be much appreciated! πŸ˜„
      driven
      any plugins, materials or imported model added recently?
      renderers can have this kind of effect...
        Have you recently changed your screen layout, multiple monitors?
          art92
          Thanks everyone for your responses!
          I got a response from sketchUp support which is as follows...
          Note: (I tried option 4 just turned off ruby and back on) it saves as usual now. 😎
          "*%(#FF4040)[For file save issues it's typically related to the filesystem on the OS.
          1. Make sure you're saving locally (no external drive, no network)
          2. Make sure you're saving to a local, non-cloud based file structure as well... no Livedrive, Dropbox and Google Drive...
          3. Make sure you're using OS compatible filenames, nothing really long, try to remove non alpha-numeric characters from both filenames and folders
          4. Confirm if Extensions are in place that could affect file saves, turn off Ruby if necessary
            A) http://help.sketchup.com/en/article/1700320 ]* ".... -SketchUp support team
