    3D Truss Models
    1.5k Posts 31 Posters 977.2k Views 30 Watching
    • jujuJ Offline
      juju
      The development of the plugin has come a long way in a short period of time, thanks for the dedication!
      • pbacotP Offline
        @medeek said:
        On my Google+ page I posted some recent screenshots of the truss plugin output. One particular individual went on a rather long diatribe on the inferior nature of SketchUp as a design tool, I quote,
        "Well, if you are obsessive compulsive, sketchup is your tool. But for people who like to get projects done, there are tools that know what wood is, what lumber is, and know what the construction code is and draw in the meaningless details for you... like framing and rafters.
        SketchUp doesn't know what a solid is. Doesn't do edge detection. Doesn't know what physics is. Can't self simply. Doesn't understand physical continuity. Doesn't understand region of focus. Can't deal with camera and material intersection. SketchUp has one intuitive tool, the extrusion tool, and somehow left everything else to confusion."
        Some of his arguments I might agree with but it seems like the design community is starting to embrace SketchUp, at least more than I had realized. What made you as a designer or DIY'er decide to use SketchUp versus other design software?
        %(#4000FF)[I think the design community has already embraced SketchUp as one tool to use. But one question to your questioner, WHAT tools is he/she referring to? and why the "diatribe" (who cares?).
        I guess that's TWO questions.
        The answer to your question, for me, may verify your questioner's suspicions. SketchUp is relatively cheap and easy to learn, and came along when other apps I was using failed. I did not review a lot of softwares and it satisfied what I needed at the time.
        For what you are doing here, it may very well be a good idea for you to look at real BIM.]
        • medeekM Offline
          medeek
          The current Medeek Truss Plugin menu now has 5 icons:
          http://design.medeek.com/resources/images/truss_su_menu.jpg
          The available items are the following:
          1.) Draw Roof Truss:
          • Common
          • Attic
          • Monopitch
          • Scissor
          2.) Draw Floor Truss:
          • Floor Truss
          • TJI Joist
          3.) Draw Truss Set:
          • Valley Set
          4.) Draw Roof Rafters:
          • Gable Roof
          • Gable Roof w/ GLB
          • TJI Roof w/ GLB
          • Hip Roof
          5.) Engineering Calculations:
          • Truss (common truss types only)
          Note that the menus show additional items that are either being worked on or are planned for future releases.
          Nathaniel P. Wilkerson PE
          Medeek Engineering Inc
          design.medeek.com
          • medeekM Offline
            medeek
            I can probably link up the Beam Calculator to the plugin as well for analyzing Glulam Beams however the use of these tools still requires some basic knowledge with regards to appropriate design parameters and options.
            Medeek Beam Calculator
            (design.medeek.com)
            The other thing to note is that the engineering tools are specific to US standards at least for now:
            AWC NDS 2012 or AWC NDS 2015 (lumber, timbers, glulams, sheathing)
            and
            IBC 2015 and ANSI TPI 1-2014 (trusses)
            design.medeek.com
            • medeekM Offline
              medeek
              The truss component in SketchUp is not fully dynamic yet, however if you right click on the actual truss component and open the Dynamic Component -> Component Options dialog box you will see that you can change some options associated with the truss. The items grayed out you cannot currently change but I would like to try and make some of them dynamic as well.
              if you make a change here and then proceed with the engineering you will notice the new values are then sent to the calculator. The dynamic attributes revealed in this dialog are what is being sent to the calculator for engineering.
              design.medeek.com
              • medeekM Offline
                medeek
                I've done some maintenance on the beam calculator in preparation for integration with the Truss Plugin:
                Version 1.0.1 - 01.10.2016
                • Updated javascript front end so that selected options are properly retained.
                • Updated total load (reactions) to include applied load and selfweight over total span. Results now more closely agree with WoodWorks Sizer Software.
                • Inputs now include option for Total Span and Clear Span.
                • Removed beam configurations that are not yet complete.
                • Beam graphic now shows span geometry with supports.
                (design.medeek.com)
                At some point I need to come up with a slicker interface that allows for multiple point loads and supports but that is a job for another day.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 1.2.5 - 01.10.2016
                  • Plugin integrated with the Medeek Beam Calculator.
                  • Engineering of North American glulam beam sizes enabled (Western, Southern Pine).
                  Also note that the Beam Calculator has a very nice PDF report output than can include client and job information.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Screenshot of the Beam Calculator that will pop up when called from the plugin:
                    http://design.medeek.com/resources/images/truss_su53_800.jpg
                    So far I only have glulam beams as an option in the plugin but I will probably add LVL, LSL, PSL and Solid Sawn and those can also be analyzed with this same interface.
                    design.medeek.com
                    • jujuJ Offline
                      juju
                      Is the manual a WIP?
                      • medeekM Offline
                        medeek
                        My wife is helping with the manual. I'm also going to make a few tutorial videos per some requests from other users. I think at this point the plugin is complicated enough it warrants more complete documentation.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          First tutorial video:
                          design.medeek.com
                          • pbacotP Offline
                            Watched the video. Good job! Quite clear and nice to watch.
                              glro
                              thank you for the video
                              i remember the difficult part, when i was designing wooden structures, was the connections between the members...
                              designing the connections might be a useful feature
                              i am longing to see a video about how you use the parameters in the dynamic component dialog box, as an input for your web calculator...
                              • facerF Offline
                                facer
                                IFC Classifications
                                I do not see IFC definitions of the truss components.
                                Will this be included in future versions of your plugin/extension?
                                T2H BuildingStructureTools (by Tak2hata) is a good example of the implementation
                                of SketchUps IFC Classifications.
                                Keep up the good work - I learn a little more about Trusses
                                with each or your new posts 😄
                                • medeekM Offline
                                  medeek
                                  I have not even looked into the IFC classifications yet. At this point I'm not even sure how to classify a truss with that classification system. I will look into that further.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Engineering Video:
                                    The SketchUp model used in the video can be found here:
                                    3D Warehouse
                                    (3dwarehouse.sketchup.com)
                                    All of my sample models can be found here:
                                    3D Warehouse
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Valley Truss Set:
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Hip Roof Framing:
                                        3D Warehouse
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Somewhat of an aside for other plugin developers or those using the API to create geometry:
                                          I found with the compound miter cuts required for the hip roof framing that the easiest way to handle this was by doing a push pull to the correct length so that one side of the member was the correct length and then actually selecting an edge or vertex and moving this separately to create the angles required. In some cases this can get a little messy since it may introduce extra lines that bisect a plane but some simple logic can then delete those extraneous lines after the fact. I don't know if this is the most efficient method to do this sort of thing but after some testing I managed to get it work very reliably.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            My wife says I need to stop clearing my throat as I talk, other than that I think they mostly get the point across.
                                            I'm still working on the manual, I've been busy the last few days so progress is slow. I've been looking around at other plugins the last few days and I'm beginning to wonder if my price point on this might be too high, most plugins are either free or a few dollars. Feedback in this regard is very much appreciated. I don't intend on making a lot of money on this project but I feel that I should at the same time be fairly compensated for the time and effort I have devoted.
                                            design.medeek.com
                                            • 65
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 75
                                            • 76
                                            • 67 / 76
