    Changing Command Icons of the Toolbar
    19 Posts 7 Posters 4.0k Views 7 Watching
      Mr.K.1
      Well I tested a couple of ideas on this and it doesn't seem to work, Ruby has very limited reach into SU tool/menu system so you can only really add things and not change them once that is done.
      You could do a little cheat by making two identical toolbars then hide the first and show the second, and vice versa.
      But again Ruby has no control over how the toolbars are positioned so it may end up being a silly jumping button.
        If you create your toolbar within the tools module/class and then refer to the definition of the command as class variable - e.g.
        @@cmdA=UI::Command.new("MyToolA"){Sketchup.active_model.select_tool(MyModule.MyToolA.new())} @@cmdA.small_icon=File.join(File.dirname(__FILE__),"MyImages","myToolA_Green.png")
        etc... then as circumstances change the image file that's used...
        @@cmdA.small_icon=File.join(File.dirname(__FILE__),"MyImages","myToolA_Red.png")
        etc...
        You can therefore have your various tool-commands permanently referenced as @@cmdA, @@cmdB etc and swap their icons, tooltips and so on, as circumstances change...
        πŸ€“
          Anton_S
          Thanks TIG, but I already tried that way and it didn't work after the command was added to the toolbar, u can refer to the Mr.K post above.
            It will change ToolTips etc so perhaps if you hide/show the toolbar ? πŸ˜•
              Mr.K.1
              Ya I tried this several ways, text does change but the icons never do(hide, show, remove toolbar and add it again nothing changes).
              It seems SU only loads those images once and they can't be refresh through Ruby.
                Yup. Seems that only the tooltip in the Command objects are actually linked to the toolbar objects it represent. The rest seem to be forgotten. 😞
                  Bum! 😞
                  The best you could do then for something like a 'Play' > 'Stop' button is to have two buttons side by side, with one disabled [grayed-out] if the other one is enabled - using a validation_proc...
                    @tig said:
                    Bum! 😞
                    Or for Play/Stop, just make the Play button pressed or not pressed - using MF_CHECKED and MF_UNCHECKED.
                      Anton_S
                      @thomthom said:
                      @tig said:
                      Bum! 😞
                      Yeah Thanks!...
                      This would not be a bad idea.
                      I think changing toolbar icons should be part of SU 9 wishes. πŸ˜„
                        maricanis
                        I've found this rather old topic, and have a question is it possible now to change toolbar icons.
                        I would like to change tool icon when some variable (@@active_extension) is changed.
                        [ruby]@@activateCmd.set_validation_proc(){
                          puts "Active #{@@active_extension}"
                          puts "before #{@@activateCmd.small_icon}"
                          if @@active_extension == 'ext1'
                            @@activateCmd.small_icon = File.join(icons_dir,"ext1_16.png")
                            @@activateCmd.large_icon = File.join(icons_dir,"ext1_24.png")
                          elseif @@active_extension == 'ext2'
                            @@activateCmd.small_icon = File.join(icons_dir,"ext2_16.png")
                            @@activateCmd.large_icon = File.join(icons_dir,"ext2_24.png")
                          puts "after #{@@activateCmd.small_icon}"
                          MF_ENABLED
                        }[/ruby]
                        This part of code validates command and prints correct icon path (which is changed in accordance with @@active_extension variable), but tool image in toolbar is not updated.
                        I've also tried to put this change not in set_validation_proc(), but in code after variable is changed. Again correct values are printed, but image remains the same.
                        Thanks in advance,
                        Marija
                          Anton_S
                          Hi Marija, I just tested changing icons on SU2016, on Windows OS, and it still doesn't work.
                            maricanis
                            Thanks Anton,
                            I was thinking, that I'm doing something wrong, but it seems that this behaviour is not changed yet.
