    My lines look awful, why? Please help
    14 Posts 8 Posters 3.7k Views 8 Watching
    • L
      longdraws
      Thank you all so much! I have cracked it now with the help of you guys. Any other tips to make this look better? I still have to put in the taps etc but would love any help on getting colour right and adding a more realistic feel to the drawing.
      Thanks LD
        Hi Liz, I think it looks pretty good but I believe I'd get rid of the extensions due to the way they look on the rim of the bath tub and on the window frame. I'd also adjust the wood grain direction on the sink stand so the grain on the shelf, top, and drawer run horizontally.
        • GaieusG
          Yes, extensions can look nice but not on exploded curves (like on the batch tub). As opposed to that glass cover in front of the shower (where they do not cause this ugly look). Also, there seem to be a bunch of extra (unneeded) endpoints due to broken edges on the window frames. They do not look nice with any of these articulated endpoint styles either.
          • pbacotP
            yeah but if you like the extensions, you can work on the drawing some.
            When you feel like you want to try some plugins: Remove the vertices in the middle of continuous lines with this plugin: http://forums.sketchucation.com/viewtopic.php?t=37619#p332047
            Recurve the curves on the bathub (removes endpoints in the curve) with this plugin: http://forums.sketchucation.com/viewtopic.php?f=323&t=36822&start=0
            Also note that the basin and some other components have rounded edges. This is more natural looking than sharp corners. A lot of people use this plugin (don't overdo the number of sides): http://forums.sketchucation.com/viewtopic.php?f=323&t=20485&start=0
            It's best to work without plugins where you can, at least at first. I don't meant to corrupt. Just a heads up.
              You can maybe alos use this free prog on your final image ?
              Fotosketcher
              • L
                longdraws
                Thanks Gai, I'll try that. Do I just use the Styles window to alter the lines on the curve or do I need the plug-in's? And, do you have to pay for the plug-ins?
                Thanks,
                LD
                  Most plugins are free. The ones to which Peter refers are.
                  • pbacotP
                    Thanks,
                    LD
                    Disabling the endpoints in the style will indeed make the curve edges cleaner looking.
                    You may also wish to consider if that tub is just too angular and curves with more segments might make it look better, especially at the ends. SU doesn't have real circles and curves. They are made up of line segments. These can be made into "Curves" where they are a single continuous entity (like an arc) (and won't show endpoints), but they still look like one line after another in the drawing. Enough of these segments and it begins to actually look rounded, depending on the view. Too many segments and your file becomes over-loaded with polygons, perhaps unnecessarily, and performance suffers. ("Smoothed" is another matter, which makes the tub side surfaces actually look softly curved--you will get the idea after awhile if you haven't as yet.)
                    • B
                      bobomyrat
                      I have upgraded my Video Card from (GeForce GT 540M) to (AMD Radeon R9 1024SP) which is almost 5 times powerful than my previous video card. But for some reasons my lines on sketchup look awful !! I have attached some pictures. Can someone help me with this problem if you understand what is the issue? How to make my lines look more sharp and clean as before. I have played around in sketchup GL settings but nothing helped.
                      Thank you
                      • Jean LemireJ
                        Jean Lemire
                        Hi bobomyrat, hi folks.
                        Make sure that you have the latest driver for your graphic card.
                        Try choosing the anti-aliasing setting with the highest number.
                        On your image I see that you have highlighted one with 0X in the rightmost column. Try a 2X or even a 4X if one is present.
                        Click OK to validate then, to be really sure, quit SketchUp and restart it.
                        Just ideas.
                        Jean
