    Shapes in LayOut: Combining, Cutting holes, etc.?
    layout
    14 Posts 9 Posters 11.1k Views 9 Watching
    • KrisidiousK
      Krisidious
      to accomplish it you have to think as you would about a hatch...
      By: Kristoff Rand
      • P
        pcmoor
        another technique would to select a shape say a circle, make the fill transparent by clicking the button in the shape styles, then increasing the stroke by entering say 20 thus creating a doughnut
        • JClementsJ
          JClements
          Thanks for the quick replies.
          John
          • KrisidiousK
            Krisidious
            I love how different brains come up with different ways to solve the same problem.
            By: Kristoff Rand
            • pbacotP
              You can also create a shape in SU then copy and paste into LO. However it remains a SU object or if you explode it (under vector style) you have a LO shape but one that is not really nicely editable.
              • RichardR
                Richard
                Unfortunately mate there is no function to do so! I do a lot of logos using LO and the only workaround is as Kistoff suggests, create something like a "C" shape with the ends closed, you can then use the slice tool to get rid of the excess where they join if needed.
                It is a function that I've requested multiple times!
                BUILTBRAND.COM.AU
                • JClementsJ
                  JClements
                  Another solution would be for LayOut to be able to import common vector graph formats such as pdf, svg, ai.,etc, and then save it to their internal format.
                  • RichardR
                    Richard
                    Or have a bunch of shapes by default that can be edited!
                    BUILTBRAND.COM.AU
                    • G
                      greengeorge
                      Actually yes you can. Use the split tool to split somewhere on the outer edge and then continue from one of the newly splid points inside, drawi the inside edge and then finish on the other newly split point. Lastly double click on the shpe and drag both of the new points so they overlap.
                      • RichardR
                        Richard
                        That still doesn't really create a proper hole, but like a letter "C" with the opening joined. Assuming I'm following your suggestion correctly!
                        BUILTBRAND.COM.AU
                          ScottBold
                          Really helpful thread, I was pulling my hair out a bit, but the download and tips from posters - all sorted. Thank you!
                            agrazdi
                            How about this trick ..
                            The answer is in the 15 second of the gif.
                            Basic Test
