    Context menu selector filter and smartmodelling
    6 Posts 3 Posters 800 Views 3 Watching
      juan974
      Hi All,
      I want to migrate from SU8 to SU2015, i installed a lot of plugin during years, and use many of them (not all of them).
      I try the old procedure that is to copy all files in "C:\Program Files (x86)\Google\Google SketchUp 8\Plugins" to "C:\Users\gilles\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins".
      Et voila, lot of error while loading plugins in SU2015.
      So i decide to make clean install them.
      1 - I need your help to find this one : context menu selector filter
      2 - Sadly the great SmartModelling is no more supported, have you an another option ?
      Thank in advance
      juan974 (Réunion island)
      website : http://sketchucation.com/click.php?url=http://www.tarn.us
        kaas
        1. maybe its ThomThom's selection toys?
        2. I never used the SmartModelling tool so I have no idea
          juan974
          Thank you for your fast answer
          1. And yes, it s selection Toy, i guessed it only access with Gui, and i was wrong ...
          2. SmartModdelling is a chinese script, it allows you to turn edges into parallelepipeds (witch rectangular sections you can set) : smartmodelling
            juan974
            Hi all,
            About SmartModeling plugin,
            I translate it (mainly to remove non utf-8 letters) and fix some script problem.
            It works almost ... It don t like when faces are selected, so plz just select edges, no faces.
            I hope it helps.
            the cool plugin
              driven
              Jaun, you should save all the files as utf8 [without bom]...
              I still see lots of garbage otherwise...
              not tested, just looked at the code...
                juan974
                Hi driven,
                I remove the useless files and convert all to utf-8.
                To make it work i commented line 46 in module egdesTools.rb because of "bad retry"
                cool plugin
