    Animation Plugin Recommendations
    15 Posts 5 Posters 884 Views 5 Watching
    • ntxdaveN Offline
      ntxdave
      I am trying to learn to build animations in SU. In particular, I do layouts for car washes. I want to be able to build an animation of a car driving through the car wash and each of the pieces of equipment being animated as the car goes through the car wash.
      I would like some feedback on animation tools/plugins that you think would work. I have tried Keyframe Animation (trial version) and have looked at SU Animate (did not download trial). I would also like to be able to animated some water and foam (like you see in a car wash) but neither tools provide that type of capability I was wondering if there were others that you could recommend.
      As an extension of that endeavor, I have tried Lumion and LumenRT which is another concept. I like how tools like that allow me to build animations that show the entire building and etc. but they do not allow me to animated the individual pieces of equipment. It would be awesome if there was a tool that would allow me to do the equipment animation within the "walk thru" animation of the entire car wash site (building, equipment, and etc.).
        Why not ? if each part is a separate object...
        Else try Unity : it's free! πŸ˜‰
        • ntxdaveN Offline
          ntxdave
          With Lumion and LumenRT I could not animated groups/subgroups or components/subcomponents. At least if you can, I did not see that anywhere. The primary orientation of these products is camera animation. They do allow you to add items from their libraries and animated them but the animation is limited to path (i.e. the path of a vehicle or the path of a person).
          The Keyframe Animation plugin allows me to get complete control of the equipment in the car wash. I could make items (like brushes) spin/rotate, and the arms that brushes are attached to can also rotate (like up and down). I also wash able to scale groups/components and their subs. I could not do any of this with the other tools.
          IMHO a tool that would give you this type of control over objects in conjunction with the camera animation would be a big success. I realize that my car wash scenario is not the main stream but I also see others who want these types of capabilities for presenting their products/models in a 3D animated environment.
          I did take a quick look at Unity but I did not see any indication of how I would incorporate my SU model in it. Maybe I missed something.
          • O Offline
            otb designworks
            Hi Dave, you are correct that LumenRT does not do object based animation and, in my opinion, there is no really provocative solutions for OBA in SU at this time. To me, the huge limitation with OBA in SU is that it is only accomplished with scenes and having thousands of scenes never sounded like a smart way to accomplish anything.
            If you use a mac, I would highly suggest you check out Cheetah3D. It is very inexpensive for what it is capable of and has been my goto solution of OBA for years. Full key framing, excellent and fast renderer, a vibrant community forum, and development is ongoing. Oh, and it has a physics engine so you could do what you want with the water, though that might take more time and effort than you might be willing to invest.
            You would export your model out in FBX, OBJ or 3DS formats (I use FBX). All your textures will export from SU and import in Cheetah and then you can take advantage of Cheetah's node-based material editor
            Cheers, Chuck
            OTB Designworks is on Youtube
            • ntxdaveN Offline
              ntxdave
              Thanks for the reply. I use Windows - actually Windows 10.
                πŸ˜‰
                http://docs.unity3d.com/Manual/HOWTO-ImportObjectSketchUp.html
                • ntxdaveN Offline
                  ntxdave
                  Thanks @Pilou, I will take a better look at it.
                    driven
                    did you have at look at this one?
                    @pilou, I thought you were a fan of this French plugin...
                      Yes i have made some little videos here : Divers / Simfonia/ πŸ˜‰
                      • ntxdaveN Offline
                        ntxdave
                        Thanks for sharing. Now if only I spoke French β˜€
                        I think you convinced me to give it a try 😎
                          It's not that can we call an easy intuitive plugin! πŸ˜‰
                          Ask a certain learning curve! πŸ€“
                          • ntxdaveN Offline
                            ntxdave
                            A concern I have is that the web site says Copyright 2012. When was the last time the software was updated? Also, the trial Functionality seems pretty limited and I cannot get a good feel for how much the software costs (I will need to let management know if we like it).
                            Going to try it this week though.
                              From the site last update seems for SU 2013 ! So try if that yet work with newer SU versions
                              Free version allows you to make 10 seconds animation!
                              Of course sufficient for test functions but not if you want more directly!
                              (you can also make some past of different animations if you are tricky! πŸ˜‰
                              Prices was 50 to 200 € following versions
                              All docs
                              • Bob JamesB Offline
                                Bob James
                                I would recommend you take a look at SimLab Soft
                                301 Moved Permanently
                                (www.simlab-soft.com)
                                • ntxdaveN Offline
                                  ntxdave
                                  All docs
                                  Having problems with installation. I have sent them a note. Will see if I get any reply.
                                  Might be a problem because I am running SU 2015 on Win10.
                                  I have printed off and read some of the documentation. I agree that it looks like it could be kind of complicated but powerful if I can get it going. The 10 second limit for the trial version might make it difficult to properly evaluate.
                                  I will give it a look............
