    Need help with opacity
    7 Posts 4 Posters 722 Views 4 Watching
    • I
      Involute
      I've made a hollow cylinder I'd like to make transparent (simulating clear acrylic). I've painted all its surfaces Translucent_Glass_Gray and set the inner and outer surfaces to 14% Opacity. Nevertheless, as you can see in the attachment, the setting only seems to be affecting the outer surface. I should be able to see the part of the model projecting inside the cylinder. What am I doing wrong? This is SketchUp Pro 8 on Windows 7 x64. Thanks for your help.
      • F
        fred.dy
        on dirait que les faces internes ne sont pas transparentes
        • I
          Involute
          En anglais, peut etre. Ma Francais nes pas tres bien. 😉
            Paint the back faces with your transparent material.
            Note: Green is my default back face color.
            • I
              Involute
              Thanks.
              • L
                LARV
                Kan du svara på svenska nästan gång så alla fattar vad du skriver...
                • I
                  Involute
                  Glöm inte Klingon.
