    Way to measure these angles?
    8 Posts 6 Posters 831 Views 6 Watching
      djd711
      Hey folks I could do with some help on the best way to measure angles for many lines within Sketchup. Firstly let me explain the workflow.
      I have 2 .dxf files which show me the top down layout and also the side profile for a rollercoaster. I imported these in to Sketchup and after much time and patience I mapped the points from one plan to the other to give me this:
      http://i.imgur.com/TqXw4uB.jpg
      Honestly It's not really important how I got to this point but I thought I would start from the beginning anyway.
      So what you see there is a representation of the top of a rollercoaster spine box beam. Just to be clear this is what I mean:
      http://i.imgur.com/vMKfaBz.jpg
      Is there a way to measure the exact angle of rotation for the lines highlighted in blue?
      http://i.imgur.com/RnjIuFt.jpg
      I need to know the angles from 0 to 360 degrees for every one of those types of lines as it follows around the track. I have tried the protractor but it gives me strange results and I find it difficult to use. It doesn't seem to line up to let me measure the angle properly. I would have to move every line to be on an axis and that's ridiculous considering the number of lines I need to measure.
      Any help would be fantastic
      Cheers, Dave
      • KrisidiousK
        Krisidious
        this is going to take a lot of time...
        you can make every line a component... then it will have an axis in it that is oriented to that line. From within that group you can measure the rotation to the next time. write it down. Repeat... good luck.
        By: Kristoff Rand
        • fredo6F
          You can use FredoTools::AngleInspector, which can measure angle between any edges, even disjoint, or between face normals, even disjoint, or from an axis.
          AngleInspector Overview
          [flash=640,480:3kv67g6q]http://www.youtube.com/v/C5Rgu3Px8V8&hl[/flash:3kv67g6q]
            djd711
            It's sort of hard to explain. The angle has to be measured in relation to the direction of the track at any given time. I think it's the horizontal axis I need.
              driven
              I've used 'Component Stringer' to help work out yaw. pitch and roll, in the past...
              yaw on the green, pitch on the blue and roll on the red...
              I would think you will need all three to describe the rides 'flight' path...
                dtrarch
                Hello all
                Just goto the Plugin Store for several dimension apps by SLBaumgartner
                This is a real gem πŸ‘ and even provides a text group of the selected angle not just a screen visual.
                Works with v 2015 Pro
                SLBaumgartner: Angular Dimension (Windows) v1.1
                dtr
                • sdmitchS
                  sdmitch
                  Cheers, Dave
                  What angle do you want? The angle between the line and the Z axis or some other axis or plane?
                  http://sdmitch.blogspot.com/
                  • sdmitchS
                    sdmitch
                    Could you post the model(version <=2014), or a representative sample of, and diagram an instance of the angle you want measured.
