    Dimensions disappear in pdfs
    6 Posts 4 Posters 1.7k Views 4 Watching
      moonsrfr
      Help! When I export a pdf from SU 2015 pro, some people are getting them with the dimension lines there but dimension numbers themselves not. I have opened the attachment I sent them on my computer and they're there, I open them on my Iphone and they're not. Both people I sent this to have Macs. Any ideas?
      Thanks,
      Mark
        Are you exporting the PDF from SketchUp or from LayOut?
        It kind of sounds like a PDF viewer problem if you can see them on your computer. Clearly the dimensions are getting exported.
          driven
          what font are you using?
          it may be missing on ios and osx...
          • ntxdaveN Offline
            ntxdave
            I have seen times when LayOut does not show all of the dimensions even though they are in the LayOut file. I have been able to solve the problem by resizing the LayOut viewport slightly. Have not had it in the past couple of months. But I have seen it happen multiple times.
            Press F1...thank me later
              moonsrfr
              Yup. The prize goes to driven. Figured it out after I posted this initially. Got an error message on another pc that showed them but gave the error message about a bad box, and off I went on Google. Seems Adobe only recognizes something like 12 fonts, and unlike a pc which will substitute a font, the mac just decides not to bother and leaves it blank. Switched to Arial from Technical, but it has to be Arial regular apparently, and voila! So thanks all. I love it that you guys are out there and that you're so responsive. Especially with the obscure and weird things I seem to come up against.
              Mark
              • ntxdaveN Offline
                ntxdave
                That is interesting I will watch the fonts as well.
                In my case though, it was a sizing issue. When I resized the viewport, everything showed up correctly. That has happened to me multiple times.
