    [Plugin] Double line
    91 Posts 38 Posters 70.7k Views 38 Watching
    • mariochaM
      mariocha
      Negative height: This happens when you draw a wall on an existing face. this is normal, the workaround is to ask for making a group in the dialog box, or create a group with the existing face you want to draw on.
      Well, sorry to say it happens even if the face is in a group. Quite annoying.
      %(#008000)[Mario C.
      • mariochaM
        mariocha
        @edson said:
        this is what I cannot achieve. when I double-click there appears a third line on the ground and I have to press return for the wall to appear. the corner remains unhealed as in the attached image.
        Just for info. Here, on 10.10.5, double-clicking closes and heals alright.
        Hum... if a third line appears, it means a third single point has been clicked, I'd say.
        To make a closed triangular wall, the process is : click = start, click = 1st line, double-click = walls.
        As you probably figured out by now.
        %(#008000)[Mario C.
        • EdsonE
          Edson
          mario,
          double-click does not work for me. the walls only appear after I press return. and then not completely healed (see attached image). very odd.
          the only way to get healed walls is to use the double line from selection option.
          http://www.mahfuz.arq.br
          • mariochaM
            mariocha
            @edson said:
            mario,
            Very odd indeed.
            Huh... btw, I do not see that double line from selection option. 😳
            %(#008000)[Mario C.
            • EdsonE
              Edson
              you can find it at Draw>Double Line>Double Line from selection or in the toolbar at View>Toolbar Palettes>Double Line (third icon down).
              • mariochaM
                mariocha
                Well, as you said, odd it is. There is no Double Line from selection sub/option under Draw. AND no toolbar
                Do we have the same version of it ?
                Mine is from a fresh download from Sketchucation Store, D.Bur, Double Line v6X
                %(#008000)[Mario C.
                • Bob JamesB
                  Bob James
                  Works fine from Draw menu (except it's "Draw>Double Line" not "Draw>Double Line>Double Line", but there is no toolbar called "Paletts" (or "Double Line" as could be expected).
                  I note that it says "third icon down". This seems to imply that "Paletts" is a master toolbar perhaps loaded by another extension?
                    driven
                    Bob.
                    View>Toolbar Palettes is a mac thing...
                    that's where we find our toolbars...
                    • EdsonE
                      Edson
                      there you have it Bob: the Double Line toolbar and the menu item View>Tool Palettes. as already mentioned, "a Mac thing."
                        driven
                        Edson, I just realised we are using different versions...
                        mine is from here [without the toolbar] but works...
                        yours is from Extension Warehouse , so I just installed it and it fails to close the wall as you describe...
                        • EdsonE
                          Edson
                          I wonder if we could get some help from Didier, the author, or from TIG.
                            driven
                            the one with the toolbar is scrambled, so you'll need to PM Didier...
                            Tig's update to the old one works fine,but is lacking some features...
                            • mariochaM
                              mariocha
                              huh... Edson, I see you have 1001bit. What do you think of the wall tool in there ? Quite similar to Dline, no ?
                              %(#008000)[Mario C.
                              • EdsonE
                                Edson
                                I use it from time to time and quite like it. the problem i find with it is that each time you use it you have to go adain over many steps to get it in drawing mode. it remembers the last parameters used, though.
                                if I remember well I started using it after Double Line pissed me off.
                                by the way, 1001bit is full of very useful tools.
                                • C
                                  complexart
                                  Hi @Didier-Bur, thank you for the tool. Is it possible to make <double line from selection> to work with line on a surface? I am trying to use tool to create grooves on a surface from a single line. My hack now is to use it to create a "groove" or Ridge with negative or positive values and join one by one to surfaces that I need a groove.
                                  • 5 / 5
