    V5 Beta MOI 3D on MAC / PC April 2022 !
    207 Posts 13 Posters 199.0k Views 13 Watching
      Dimensions more and more effective! πŸ˜‰
      http://s6.postimg.org/778mmpsb5/dimdim2.gif
      http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=aceeaa3c3928686d25b9d3b0759d5ff6&filename=Arrow type 5_2.gif
      http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=6870661cdba89c3ad15275dec23120cc&filename=Arrow type 5.gif
        By Chri
        http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=f72e2676526b216daf05a5a0b5161405&filename=1.gif
        http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=33bd570392acb81860f07fb4ba879a44&filename=2.gif
          Angles arrived! πŸ˜‰
          and arc circles lenght !
          http://s6.postimg.org/n6qvafjwx/circle_no.jpg
          http://s6.postimg.org/gdqie5t3l/tricky.gif
            Dimension of curves! πŸ‘
            http://moiscript.weebly.com/uploads/3/9/3/8/3938813/752243595.php
              Dimensions
              Release candidate πŸ˜‰ v.99
              Added:
              Feet/Inches format
              Angles > 180
              Type names
              Type 6 activates circular mode automatically
                Exotic! πŸ˜„
                  HeightMap by Max Smirnov!
                  Transform image in volume! 😎
                  French version πŸ˜‰
                  http://moiscript.weebly.com/uploads/3/9/3/8/3938813/2900845_orig.png
                  http://moiscript.weebly.com/uploads/3/9/3/8/3938813/6593904_orig.jpg
                  By Max Smirnov
                  http://moiscript.weebly.com/uploads/3/9/3/8/3938813/5387760_orig.png
                  http://moiscript.weebly.com/uploads/3/9/3/8/3938813/9473716_orig.jpg
                  http://moiscript.weebly.com/uploads/3/9/3/8/3938813/3966776_orig.jpg
                  • olisheaO
                    olishea
                    Pilou, I just bought MOI3D! Time to get sculpting!
                    oli
                      @ Olishea
                      Bienvenue to the club! πŸ˜„
                      Have fun modeling with it! πŸ˜„
                      Sure a little less powerful than Rhino but... 😎
                      Don't hesitate for any questions!
                      Here or on the Moi forum where you have direct access with the creator Michael Gibson with very detailed answers!
                      And this is priceless! πŸ‘
                      Chipp Walters is fan of it! πŸ˜„
                      • olisheaO
                        olishea
                        @pilou said:
                        @ Olishea
                        Thanks Pilou! And thanks for updating this thread, I keep watching the videos.
                        I am only using MOI for 3D printing projects, so I don't need Rhino....I got tired of trying to make SU do what I wanted. Even just simple intersections/booleans were sending me crazy.
                        I will surely be frequenting the forum with LOTS of questions haha!
                        oli
                          It's perfect for that and others materials! πŸ˜„
                          By Samuel Zeller from this creepy original image!
                          http://i.imgur.com/uY9Nuwf.png
                          Redrawing in Moi
                          http://i.imgur.com/jO3taec.jpg
                          Result! 😎
                          http://i.imgur.com/XEh3lLh.jpg
                          No Problem we are on the same Greenwich Time Zone! πŸ’š
                            Array3D by Max Smirnov
                            • olisheaO
                              olishea
                              this guy is firing out some impressive plugins isnt he!
                              oli
                              • olisheaO
                                olishea
                                the subdivide plugin is exactly what i needed!
                                oli
                                  SUbdivision
                                  Will work fine with Bridge, Split πŸ˜‰
                                  New version of Array 3D : Random, Base/ target
                                  • olisheaO
                                    olishea
                                    OK I got all the scripts installed, time to have some fun!
                                    I put the scripts in the command folder but I can't see them anywhere when I open MOI? There are no buttons/icons?
                                    I feel like a newb again! πŸ˜„
                                    oli
                                      You can make 2 things! πŸ˜„ (if you have a PC ? )
                                      Press Tab and write the name of the plugin!
                                      Here the subdiv's name script is _Subdiv_6 (no sensitive case)
                                      Or make a shortcut ! Menu Options (bottom screen) / ShortCuts
                                      Put in the left column any combinaison of keys
                                      and on the right column _Subdiv_6 πŸ€“
                                      Have fun modeling !
                                      • olisheaO
                                        olishea
                                        OK I will have another go. I am using both PC and Mac...just to confuse you! πŸ˜„
                                        oli
                                        • olisheaO
                                          olishea
                                          I am just using my Mac at the moment to have a play....but I am still confused.
                                          I have pasted the script into the commands folder.
                                          Opened up MOI.
                                          Added shortcut.
                                          Then I get the error message? I am simply subdividing a cube for this test.
                                          oli
                                            Try with _subdiv_beta6 as you have in your list's files πŸ’š
                                            Sorry for the confusion, i had changed my name of file! 😳
                                            After the writing name, of course Enter! πŸ€“
                                            Ps Of course you can make a Copy / Past of this name file from a Text file of numerous scripts!
                                            (because install more "easy" is some time losted at the beginning : play first with the toy) 😎
                                            I have these Shortcuts for the "subdivision" modeling process)
                                            • 11
                                            • 6 / 11
