    V5 Beta MOI 3D on MAC / PC April 2022 !
    207 Posts 13 Posters 141.4k Views 13 Watching
      Array3D by Max Smirnov
      • olisheaO Offline
        olishea
        this guy is firing out some impressive plugins isnt he!
        oli
        • olisheaO Offline
          olishea
          the subdivide plugin is exactly what i needed!
          oli
            SUbdivision
            Will work fine with Bridge, Split πŸ˜‰
            New version of Array 3D : Random, Base/ target
            • olisheaO Offline
              olishea
              OK I got all the scripts installed, time to have some fun!
              I put the scripts in the command folder but I can't see them anywhere when I open MOI? There are no buttons/icons?
              I feel like a newb again! πŸ˜„
              oli
                You can make 2 things! πŸ˜„ (if you have a PC ? )
                Press Tab and write the name of the plugin!
                Here the subdiv's name script is _Subdiv_6 (no sensitive case)
                Or make a shortcut ! Menu Options (bottom screen) / ShortCuts
                Put in the left column any combinaison of keys
                and on the right column _Subdiv_6 πŸ€“
                Have fun modeling !
                • olisheaO Offline
                  olishea
                  OK I will have another go. I am using both PC and Mac...just to confuse you! πŸ˜„
                  oli
                  • olisheaO Offline
                    olishea
                    I am just using my Mac at the moment to have a play....but I am still confused.
                    I have pasted the script into the commands folder.
                    Opened up MOI.
                    Added shortcut.
                    Then I get the error message? I am simply subdividing a cube for this test.
                    oli
                      Try with _subdiv_beta6 as you have in your list's files πŸ’š
                      Sorry for the confusion, i had changed my name of file! 😳
                      After the writing name, of course Enter! πŸ€“
                      Ps Of course you can make a Copy / Past of this name file from a Text file of numerous scripts!
                      (because install more "easy" is some time losted at the beginning : play first with the toy) 😎
                      I have these Shortcuts for the "subdivision" modeling process)
                      • olisheaO Offline
                        olishea
                        yes pilou! good spot!
                        thanks for the advice. I am loving MOI so far!
                        oli
                          yes, it's a true gem πŸ˜„
                          New version of the _array3d πŸ˜‰ speed*2!
                          • olisheaO Offline
                            olishea
                            Nice! I got Subdivision to work thanks very much mate!
                            I just need to work out how well a subdivided solid exports.....when I export to OBJ or STL it seems to go quite jagged even at high resolution/poly.
                            oli
                              Example, image, files ? πŸ’š
                              • olisheaO Offline
                                olishea
                                It's OK I'll sort it out. All the mesh previews look unsmoothed when uploaded to the 3D printing websites. It's more noticeable in the first image....it could be because i'm trying to subdivide and then punch holes/fillet afterwards and it causes a messy mesh. The fillets are a different resolution to the subdivided mesh so some conflict will occur. I'll get there I'm just being silly. πŸ˜„
                                oli
                                  File 3DM?
                                  In waiting a little tut by Chipp Walters
                                        VoronoΓ― Diagram by Max Smirnov
                                        Select Voronoi: Name it, Select Polygon: name it
                                        Select Voronoi's lines
                                        Call Boolean Inter
                                        Click Polygon
                                        Et voilΓ ! πŸ˜„
                                        http://moiscript.weebly.com/uploads/3/9/3/8/3938813/570504_orig.jpg
                                        http://moiscript.weebly.com/uploads/3/9/3/8/3938813/3263482_orig.gif
                                        • olisheaO Offline
                                          olishea
                                          does it work in 3D?! πŸ˜„
                                          oli
                                            You can make yet some things with it! πŸ˜‰ (and it's work in progress! ) πŸ€“
                                            • 11
                                            • 7 / 11
