    V5 Beta MOI 3D on MAC / PC April 2022 !
    207 Posts 13 Posters 136.8k Views 13 Watching
      @ Olishea
      Bienvenue to the club! πŸ˜„
      Have fun modeling with it! πŸ˜„
      Sure a little less powerful than Rhino but... 😎
      Don't hesitate for any questions!
      Here or on the Moi forum where you have direct access with the creator Michael Gibson with very detailed answers!
      And this is priceless! πŸ‘
      Chipp Walters is fan of it! πŸ˜„
      • olisheaO Offline
        olishea
        @pilou said:
        @ Olishea
        Thanks Pilou! And thanks for updating this thread, I keep watching the videos.
        I am only using MOI for 3D printing projects, so I don't need Rhino....I got tired of trying to make SU do what I wanted. Even just simple intersections/booleans were sending me crazy.
        I will surely be frequenting the forum with LOTS of questions haha!
        oli
          It's perfect for that and others materials! πŸ˜„
          By Samuel Zeller from this creepy original image!
          http://i.imgur.com/uY9Nuwf.png
          Redrawing in Moi
          http://i.imgur.com/jO3taec.jpg
          Result! 😎
          http://i.imgur.com/XEh3lLh.jpg
          No Problem we are on the same Greenwich Time Zone! πŸ’š
            Array3D by Max Smirnov
            • olisheaO Offline
              olishea
              this guy is firing out some impressive plugins isnt he!
              oli
              • olisheaO Offline
                olishea
                the subdivide plugin is exactly what i needed!
                oli
                  SUbdivision
                  Will work fine with Bridge, Split πŸ˜‰
                  New version of Array 3D : Random, Base/ target
                  • olisheaO Offline
                    olishea
                    OK I got all the scripts installed, time to have some fun!
                    I put the scripts in the command folder but I can't see them anywhere when I open MOI? There are no buttons/icons?
                    I feel like a newb again! πŸ˜„
                    oli
                      You can make 2 things! πŸ˜„ (if you have a PC ? )
                      Press Tab and write the name of the plugin!
                      Here the subdiv's name script is _Subdiv_6 (no sensitive case)
                      Or make a shortcut ! Menu Options (bottom screen) / ShortCuts
                      Put in the left column any combinaison of keys
                      and on the right column _Subdiv_6 πŸ€“
                      Have fun modeling !
                      • olisheaO Offline
                        olishea
                        OK I will have another go. I am using both PC and Mac...just to confuse you! πŸ˜„
                        oli
                        • olisheaO Offline
                          olishea
                          I am just using my Mac at the moment to have a play....but I am still confused.
                          I have pasted the script into the commands folder.
                          Opened up MOI.
                          Added shortcut.
                          Then I get the error message? I am simply subdividing a cube for this test.
                          oli
                            Try with _subdiv_beta6 as you have in your list's files πŸ’š
                            Sorry for the confusion, i had changed my name of file! 😳
                            After the writing name, of course Enter! πŸ€“
                            Ps Of course you can make a Copy / Past of this name file from a Text file of numerous scripts!
                            (because install more "easy" is some time losted at the beginning : play first with the toy) 😎
                            I have these Shortcuts for the "subdivision" modeling process)
                            • olisheaO Offline
                              olishea
                              yes pilou! good spot!
                              thanks for the advice. I am loving MOI so far!
                              oli
                                yes, it's a true gem πŸ˜„
                                New version of the _array3d πŸ˜‰ speed*2!
                                • olisheaO Offline
                                  olishea
                                  Nice! I got Subdivision to work thanks very much mate!
                                  I just need to work out how well a subdivided solid exports.....when I export to OBJ or STL it seems to go quite jagged even at high resolution/poly.
                                  oli
                                    Example, image, files ? πŸ’š
                                    • olisheaO Offline
                                      olishea
                                      It's OK I'll sort it out. All the mesh previews look unsmoothed when uploaded to the 3D printing websites. It's more noticeable in the first image....it could be because i'm trying to subdivide and then punch holes/fillet afterwards and it causes a messy mesh. The fillets are a different resolution to the subdivided mesh so some conflict will occur. I'll get there I'm just being silly. πŸ˜„
                                      oli
                                        File 3DM?
                                        In waiting a little tut by Chipp Walters
                                            • 11
                                            • 6 / 11
