    Removing duplicat Component Instances from an array
    5 Posts 4 Posters 770 Views 4 Watching
      ktkoh
      I am having a problem trying to eliminate duplicate Component Instances from an the selection array. If the user selects more than one instance of a component I want to eliminate that from the array before operating on the selection. Suggestions would be appreciated.
      Keith
        driven
        ['a','a','b','c'].uniq
        ["a", "b", "c"]
        doesn't uniq work?
        • TIGT Online
          Because each instance has its own unique reference you'll need to use their actual definitions to get a reduced list.
          So let's assume iarray is an array of your selected instances [up to you how you compile this...]
          Then use something like this...
          defns = [] iarray.each{|i| defns << i.definition unless defns.include?(i.definition) }
          Now you have an array of all selected definitions named defns !
          Process that...
          • Dan RathbunD Offline
            Dan Rathbun
            Or use Enumerable#grep ...
            defns = selection.grep(Sketchup::ComponentInstance){|i| i.definition }.uniq
            But, if you've already got the instances filtered then:
            defns = iarray.map{|i| i.definition }.uniq
            I'm not here much anymore.
              ktkoh
              Thanks for the help I just got to part of the program where this is needed. I visulized 6 to10 lines of code knowing that unique would work directly.
              Keith
