    PLS HELP: My Render Going To Error
    renderpluginsextensions
    9 Posts 4 Posters 1.1k Views 4 Watching
    • Z Offline
      zachconcept
      Dear Expert,
      Please help...I tried to render my design, but the white wall color is error and looks like there are bricks there. But I never choose the color yet. How to fix it? Please advise...Thanks
      Regards,
      Zach
      look at the wall....messy paint..
      • Z Offline
        zachconcept
        Hi Expert,
        I just tried to switch off the layer of wood floor (with bump and displacement setting) just now, and the wall is going back to normal....however, when I turned on the wood floor, the the wall just error again....please need your help how to fix it please??? Many thanks
        Zach
        • ely862meE Offline
          ely862me
          Maybe you applied the floor material to the other side of the wall and on this side you only see the bump map ?
          Elisei (sketchupper)
          Come and See EliseiDesign
          • Z Offline
            zachconcept
            Hi, thank you for reply..I did not applied the material to the other walls....it has ensured that material applied to the floor only...Please advise...Thanks.
              rspierenburg
              Make sure if you are using displacement on the floor that it is grouped by itself, otherwise Vray will attempt to bleed the displacement onto everything that touches that face.
              • Z Offline
                zachconcept
                Hi...thanks for your reply...
                I have already made a group for each but the result is still the same...any ideas? Please advise...Thanks
                I have made a group for the fabric (bump and displacement)
                I have made a group for the bench (reflection only)
                the render result on the bench is still like this, not a glossy paint.
                • chonC Offline
                  chon
                  Hello,
                  Do you have a bump or displacement bitmap on your material ?
                  If yes, this is a bug and your Diffuse MUST be a bitmap either... πŸ˜‰
                  • Z Offline
                    zachconcept
                    Yes....I have bitmap files. How to fix a bug? Please advise....Thanks
                    • chonC Offline
                      chon
                      Can you post screenshots of your material diffuse and material maps settings ?
