    Layout Printed Line Thickness
    layout
    11 Posts 5 Posters 2.3k Views 5 Watching
      Currently the only option for setting line weight is in points. There are plenty of converters available online and I expect you could find a table you could print out as a handy reference. Here's the first hit from a quick Google search.
        seasdes
        Thank you Dave. I never stop learning.
        Using Sketchup Pro 2019
          You're welcome. It's a good thing you never stop learning. You should only stop when your pump finally quits. πŸ˜‰
            seasdes
            That's the way that I think.
            • RichardR Offline
              Richard
              AND, Dave never stops teaching! πŸ‘ πŸ‘ πŸ‘
              [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                seasdes
                I am always been told πŸ˜„
                  agrazdi
                  I thougth it would apply to text size too.
                  It didnΒ΄t work for me
                  I wonder if text should be converted by other method
                    You might find it useful to do some reading about font design. The font height includes some space above and below the glyphs. some of that space is for ascenders and decenders and then there's some additional space on top of that.
                    This is a good reference.
                      KrisM
                      Fonts seem to occupy their own universe. If you look at five different fonts, all at 20 pts, they will all be different heights. You will have to decide which font you want to use, determine what its actual height is relative to your required point size and adjust the point size accordingly.
                      • RichardR Offline
                        Richard
                        Cheap or freely sourced fonts do have this tendency! Fonts from reputable foundry tend to follow proper protocols!
