    Webdialog - getting started?
    21 Posts 7 Posters 2.2k Views 7 Watching
      abakobo
      I'm using SKUI and stopped the pain of webdialog learning... you do a lot of things with it!
      http://www.thomthom.net/thoughts/2013/07/skui-a-gui-framework-for-sketchup/
        You might want to have a look at this GitHub repo I've put together with info about how to deal with WebDialogs: https://github.com/thomthom/sketchup-webdialogs-the-lost-manual
        • greenskpG Offline
          greenskp
          Thomthom, do you have a manual for SKUI showing all features availables?
            Afraid I got no published docs. But it's marked up with YARD so you can run that on the SKUI folder and you'll get a compiled HTML doc set.
            http://yardoc.org/
            • Dan RathbunD Offline
              Dan Rathbun
              http://yardoc.org/
              GitHub repos can be linked to generate YardDocs automatically. You as the owner of the repo need to flip the switch.
              I'm not here much anymore.
              • greenskpG Offline
                greenskp
                I ran inside src >> SKUI folder and i got a blank page ๐Ÿ˜ž
                I also ran on root folder but i see the same hosted on github.
                I would like to know how to connect value sliders to events, like the default inputbox. Maybe open child windows and so on.
                yard server
                  I should add a .yardopts file to the repo.
                  To generate docs, use the following command from the repo root: yardoc src/**/*.rb
                  Slider value? Don't think any sliders has been added...
                  How? What switch?
                    sepultribe
                    http://www.rubydoc.info/github/thomthom/SKUI
                    maybe Dan means this
                      Dan Rathbun
                      Yes, he must have found it.
                      (1) from the repo (right column) "Settings", ...
                      (2) from the Settings page (left column) "Webhooks & Services", ...
                      (3) in the Services box, in the "Add Service" dropdown picklist, ...
                      (4) choose "RubyDoc.info"
                        ๐Ÿ˜ฎ
                        I have never seen that....
                          It appear that it's automatically generating it...
                          ...or might I have added it manually at some point?
                          โ“ โ“ โ“
                            hm... I added it manually from GitHub and afterwards it's not listed anywhere that it's been activated. ...odd...
                              Dan Rathbun
                              No you have to add it somehow.
                              You must have.
                              If you follow my procedure (above,) does it then appear in the list of services ?
                                No - there was no item listed. And after manually adding it (just to see what happened) it's still not listed. But docs are still being generated... ๐Ÿ˜•
                                  sepultribe
                                  @thomthom said:
                                  [attachment=1:1sdocz38]<!-- ia1 -->2015-07-25_13h45_44.png<!-- ia1 -->[/attachment:1sdocz38]
                                  [attachment=0:1sdocz38]<!-- ia0 -->2015-07-25_13h47_40.png<!-- ia0 -->[/attachment:1sdocz38]
                                  โ“ โ“ โ“
                                  I added it (on rubydocs) when I posted my previous post.
                                    ๐Ÿ‘ ๐Ÿ‘
                                      Dan Rathbun
                                      That explains it. But the settings page on GitHub should somehow show that the service is active.
                                        I tried once more, and this time it's listed. (no idea why it wasn't earlier - but at least it's working now.)
                                        Very nice feature.
