    Webdialog - getting started?
    21 Posts 7 Posters 2.5k Views 7 Watching
    • W
      wawmsey7
      thanks for the help, that's a really useful reference!
        abakobo
        I'm using SKUI and stopped the pain of webdialog learning... you do a lot of things with it!
        http://www.thomthom.net/thoughts/2013/07/skui-a-gui-framework-for-sketchup/
          You might want to have a look at this GitHub repo I've put together with info about how to deal with WebDialogs: https://github.com/thomthom/sketchup-webdialogs-the-lost-manual
          • greenskpG
            greenskp
            Thomthom, do you have a manual for SKUI showing all features availables?
              Afraid I got no published docs. But it's marked up with YARD so you can run that on the SKUI folder and you'll get a compiled HTML doc set.
              http://yardoc.org/
              • Dan RathbunD
                Dan Rathbun
                http://yardoc.org/
                GitHub repos can be linked to generate YardDocs automatically. You as the owner of the repo need to flip the switch.
                I'm not here much anymore.
                • greenskpG
                  greenskp
                  I ran inside src >> SKUI folder and i got a blank page ๐Ÿ˜ž
                  I also ran on root folder but i see the same hosted on github.
                  I would like to know how to connect value sliders to events, like the default inputbox. Maybe open child windows and so on.
                  yard server
                    I should add a .yardopts file to the repo.
                    To generate docs, use the following command from the repo root: yardoc src/**/*.rb
                    Slider value? Don't think any sliders has been added...
                    How? What switch?
                      sepultribe
                      http://www.rubydoc.info/github/thomthom/SKUI
                      maybe Dan means this
                      • Dan RathbunD
                        Dan Rathbun
                        Yes, he must have found it.
                        (1) from the repo (right column) "Settings", ...
                        (2) from the Settings page (left column) "Webhooks & Services", ...
                        (3) in the Services box, in the "Add Service" dropdown picklist, ...
                        (4) choose "RubyDoc.info"
                          ๐Ÿ˜ฎ
                          I have never seen that....
                            It appear that it's automatically generating it...
                            ...or might I have added it manually at some point?
                            โ“ โ“ โ“
                              hm... I added it manually from GitHub and afterwards it's not listed anywhere that it's been activated. ...odd...
                              • Dan RathbunD
                                Dan Rathbun
                                No you have to add it somehow.
                                You must have.
                                If you follow my procedure (above,) does it then appear in the list of services ?
                                  No - there was no item listed. And after manually adding it (just to see what happened) it's still not listed. But docs are still being generated... ๐Ÿ˜•
                                    sepultribe
                                    @thomthom said:
                                    [attachment=1:1sdocz38]<!-- ia1 -->2015-07-25_13h45_44.png<!-- ia1 -->[/attachment:1sdocz38]
                                    [attachment=0:1sdocz38]<!-- ia0 -->2015-07-25_13h47_40.png<!-- ia0 -->[/attachment:1sdocz38]
                                    โ“ โ“ โ“
                                    I added it (on rubydocs) when I posted my previous post.
                                      ๐Ÿ‘ ๐Ÿ‘
                                      • Dan RathbunD
                                        Dan Rathbun
                                        That explains it. But the settings page on GitHub should somehow show that the service is active.
                                          I tried once more, and this time it's listed. (no idea why it wasn't earlier - but at least it's working now.)
                                          Very nice feature.
