    Graphic Performance
    44 Posts 8 Posters 5.0k Views 8 Watching
    • ntxdaveN
      ntxdave
      Last night I got to thinking about any other changes I might have made and I remembered that I updated 3 plugins. I use the Sketchucation Tools to update things and I ran the routine that looks at my installed plugins and it updated 3 of them. I remember that there was a popup screen that showed 2 plugin folders. Without thinking I just clicked and let it use the one highlighted.
      So, here are my questions:
      1. Is it possible that this caused some type of problem? In particular, if the folder the update was loaded to was different than the folder the original version of the plugin was installed in, would that create a conflict that SU could be struggling with?
      2. Since I cannot remember which 3 plugins were updated, is there any way to figure this out?
      3. Should I uninstall and reinstall each plugin?
      While I appreciate the other tips (Goldilocks in particular), I really think it has to be something like this since the performance just changed kind of suddenly and was independent of updates to the model where I have been seeing the problem. Just to verify that, I went back and found a model that has not been updated since October of 2014 and it is doing the same thing. I am also noticing that models (particularly bigger ones) are loading much slower. Something else is definitely going on that was not happening before.
      Again, thanks for all the feedback and I certainly welcome any more suggestions. I need to find a resolution to this problem. It is very annoying.
      Press F1...thank me later
      • KrisidiousK
        Krisidious
        That's a good idea trying other models.
        Now what you can do is remove all your plugins or disable them and see if the problem persists, then add them back until you find the culprit.
        If you look in the Sketchucation Plugin Store it will show plugins by update. try the last ones first.
        By: Kristoff Rand
        • ntxdaveN
          ntxdave
          Well, I have tried disabling all of my plugins and I still had the same problem. I even tried on a SU 2014 model and got the same results.
          One thing I found interesting. I went back in an enabled all of the plugins, restarted SU and then reloaded my model. My first attempts to orbit the model were fine. Then I used the middle mouse wheel to zoom in and out and the delay started happening again.
          I am stumped as to what could be causing the delay (and it is not just with textures) in repainting the model when I orbit, pan or zoom.
          Any other ideas would be greatly appreciated.
          • KrisidiousK
            Krisidious
            lets see a list of processes that are going on. did you use the task manager to look at the system resources while you experienced the issue?
            By: Kristoff Rand
            • sketch3d.deS
              sketch3d.de
              you surely have checked already that "Window > Preferences > OpenGL > USe Hardware Acceleration" is enabled...
              ... and that, if using a double-GPU system with an integrated e.g. intel GPU and the dedicated nVidia GPU, SketchUp is running on the GeForce and not the internal (slow) GPU e.g. if running in power-saving mode.
              Check the 3D Settings in the nVidia Control Panel for configuring that 3D applications in general and SketchUp in particular always use the GeForce instead of the automatic mode which tends to fail especially under W7:
              http://forums.sketchup.com/uploads/default/3768/76a71e423c2e7e22.png
              • ntxdaveN
                ntxdave
                Yes - my settings are exactly as you suggest. It was one of the first things I went and checked because I thought maybe a Windows update had somehow changed something. I also went and checked that I have the latest driver for my graphics card.
                I am confused as to why this just started happening. I also disabled all of the plugins to see if one of them may be causing the change. So far, I still have not identified why the change in performance. I am scratching my head trying to figure this out.
                I really appreciate the response though.
                • KrisidiousK
                  Krisidious
                  have you tried a system restore?
                  By: Kristoff Rand
                  • ntxdaveN
                    ntxdave
                    No - I have not tried that. Just to make sure, are you talking about a complete Windows restore or something else?
                    • KrisidiousK
                      Krisidious
                      yes, a system restore. it should not effect files. but restore back to a point before this happened?
                      By: Kristoff Rand
                      • ntxdaveN
                        ntxdave
                        When I went to do that it told me that it would reinstall Windows 8.1 and that I would have to reinstall all of my apps. That is not good. I am not going to go that far back.
                        The other thing I remembered doing lately was to sign up for Dropbox. I went in and disabled it and a couple of other things lists as "high" in the startup list. I then restarted Windows and am not seeing any change. I am getting frustrated by all of this 😞
                        • KrisidiousK
                          Krisidious
                          You're on windows 8? Are you sure you tried to restore and not tried to repair?
                          By: Kristoff Rand
                          • ntxdaveN
                            ntxdave
                            I thought that is what it said. I clicked on the option that said my files would not be bothered but it went on to say it would reinstall Windows 8.1 and I would have to reinstall all apps.
                            • KrisidiousK
                              Krisidious
                              I have 7 and that's not how it works...
                              By: Kristoff Rand
                              • ntxdaveN
                                ntxdave
                                I finally found the correct link for Win 8.1 restore.........
                                I am seeing no change in SU. Still seeing a lag when I orbit that I did not see before.
                                • KrisidiousK
                                  Krisidious
                                  That's it... We're formatting this mutha!
                                  By: Kristoff Rand
                                  • KrisidiousK
                                    Krisidious
                                    are you using the same style in all these models?
                                    By: Kristoff Rand
                                    • ntxdaveN
                                      ntxdave
                                      Yes, it is the same one I have been using for over 2 years now. Nothing in that realm has changed (that I am aware of). I first noticed this when I brought up a model I had been using for a few weeks (tweaking/cleaning up now and then). Fortunately the lag is not very long (couple of seconds) but it is still annoying and I would like to know why it has started.
                                      Generally I do not work with this type of model but I am trying to set up a model that I can used in something like Lumion, LumenRT or another such program to do a walk through of a car wash.
                                      • KrisidiousK
                                        Krisidious
                                        qany model can be used in those systems... why would you need a special one?
                                        and can you try using a simple plain style and test?
                                        By: Kristoff Rand
                                        • ntxdaveN
                                          ntxdave
                                          Normally I just put together what is called the "tunnel equipment". That is the equipment you see if you drive through the car wash. I have been working on a sample model that includes the building, the room of support equipment, the office for the car wash, and the lobby. On the outside of the building I also include both the payment booth and the vacuum system. When I put all of this together I wind up with a SU file just under 30Mb.
                                          That is where I suddenly see the lag in performance.
                                          I will send you a PM with a link to 2 versions of the file (Lumion & LumenRT). The model has a bunch of edges and other little things I have been trying to clean up.
                                          • KrisidiousK
                                            Krisidious
                                            But do you get the lag in a small simple su file?
                                            By: Kristoff Rand
                                            • 2 / 3
