    Mesh to bitmap
    5 Posts 4 Posters 572 Views 4 Watching
      Spohankie123
      I was hoping to be able to convert a mesh made in Sketchup into a bitmap I might use as a Digital Elevation Model.
      Is there a way to convert?
      • cottyC Offline
        cotty
        You can File -> Export -> 2D... and choose a bitmap format?
        my SketchUp gallery
        • JQLJ Offline
          JQL
          You can control fog to make a depth map with a parallel projection. Your height map would be limited to black and white or fog/background color and you also can't export it as 16-32bit.
          You can use a render engine like Thea to generate that depth map and export as 16-32bit format.
          www.casca.pt
          Visit us on facebook!
          • jujuJ Offline
            juju
            will something like this be of help?
            http://sketchucation.com/pluginstore?pln=normal_map_maker
            • JQLJ Offline
              JQL
              That is pretty cool but it's for normal maps wich are usually created for rendering.
              I believe this has something to do with real maps (topography, geography, that sort of stuff)...
              Are your maps color coded somehow? There is a color to height plugin somewhere but I don't think it would be accurate enough for what you need.
              www.casca.pt
