    Division along a curved path
    4 Posts 3 Posters 458 Views 3 Watching
    • B
      Bruce Watt
      I am trying to position vertical window mullions along a horizontal curved path. Therefore mullions need to be spaced equidistant long the curved path and rotated 90 degrees tangent to the curved part each mullion is positioned at.
      I can do this manually but wonder if there is a extension that would do it better.
      Apologies as I am sure this question has been asked before. Is there a plugin / extension that does this?
      SKUP PRO 2021 latest version / update
      Windows 10 Pro
      Dell Alienware Aurora R10 AMD
      AMD Ryzen™ 9 3900X
      NVIDIA® GeForce RTX™ 2080 Ti 11GB GDDR6
        Try Fredo Bezier, there are some divide tools inside!
        Then also Components Stringer by Chris Fullmer
        ANd / Or Path Copy by Rick Wilson
        • pbacotP
          If the path is a circular arc, you can use SkethUp rotate with the copy function.
          • B
            Bruce Watt
            Thank you, That is very helpful.
            All the best
            Windows 10 Pro
            AMD Ryzen™ 9 3900X
