    Get X,Y,Z of active_model with Ruby
    5 Posts 4 Posters 738 Views 4 Watching
    • kimpastroK
      kimpastro
      Hi, I swear I do a lot of research about this issue but can't find anything or can't understanding anything about what I've found.
      Just need to get the value of x,y and z of a active_model, because i'm gonna to export the project in json format and need when import to continue with they respective position.
      Ex:
      my_model['x'] = Sketchup.active_model.getX
      my_model['y'] = Sketchup.active_model.getY
      my_model['z'] = Sketchup.active_model.getZ
      the getX getY and getZ is what i need.
      If someone could help me or just link a topic about this explanation, will help me a lot.
      thanks so much guys.
        Your cod-example is very very unclear. πŸ˜•
        What " XYZ" of the 'model' are you seeking ?
        Please explain yourself better...
        I'll throw in some ideas that might help, meanwhile...
        bounds = Sketchup.active_model.bounds
        center = bounds.center ### the center point of the model's bounding box, which includes XYZ coordinates.
        min = bounds.min ### the minimum point of the model's bounding box, which includes XYZ coordinates.
        max = bounds.max ### the maximum point of the model's bounding box, which includes XYZ coordinates.
        xdim = bounds.width ### the width [X/red] dimension of the model's bounding box, in inches.
        ydim = bounds.height ### the height [Y/green] dimension of the model's bounding box, in inches.
        zdim = bounds.depth ### the depth [Z/blue] dimension of the model's bounding box, in inches.
        ### to get the three x,y,z values in inches [aka Float] of a point3d reference use...
        x,y,z = point.to_a
        ### to get a single coordinate value in current model-units [aka Length] of a point3d reference use...
        x = point.x
        ### etc... there are lots of permutations...
        • kimpastroK
          kimpastro
          > x,y,z = point.to_a
          > x = point.x
          TIG, first of all thanks for reply.
          I misunderstood the whole thing.
          The "model" I've mentioned actually is the entity that contain all children entities.
          What I do was something like that:
          if not is_children?
          position; {
            x; entity.transformation.origin.x,
            y; entity.transformation.origin.y,
            z; entity.transformation.origin.x
          Thanks again, the bound method that you've explained, resolved a few other things.
          • Dan RathbunD
            Dan Rathbun
            The origin of the active_model is [0,0,0], which is referenced as ORIGIN.
            If the model came from Google Earth, then the real world co-ordinates (in inches) will be in the GeoReference attribute dictionary.
            mdl = Sketchup;;active_model
            if mdl.georeferenced? &&
            !mdl.attribute_dictionary('GeoReference',false).nil?
                mdl.get_attribute('GeoReference', 'ModelTranslationX', 0.0),
                mdl.get_attribute('GeoReference', 'ModelTranslationY', 0.0),
                mdl.get_attribute('GeoReference', 'ModelTranslationZ', 0.0)
            else
              ORIGIN.to_a
            I'm not here much anymore.
              > else
              >   ORIGIN.to_a
              > end
              Or Model.point_to_utm
              http://www.sketchup.com/intl/en/developer/docs/ourdoc/model#point_to_utm
