    Why does my color change when adding emissive layer?
    renderpluginsextensions
    18 Posts 2 Posters 1.9k Views 2 Watching
    • andybotA
      andybot
      oh - I'd change the decay and falloff to Inverse Square & Smooth Cubic, respectively. Is physical camera turned on or off?
      • eddiemoneyE
        eddiemoney
        Physical camera on
        • eddiemoneyE
          eddiemoney
          Those changes produce basically black results...(same intensity - 20)
          • andybotA
            andybot
            Yes, yes they would. The physical camera settings are the default for a brightly lit outdoor scene. Try changing the camera settings to shutter speed 30, f number 4.0, and film speed 400. That's just a quick guess, but you can adjust those values as needed to get the right amount of exposure in the scene.
            • eddiemoneyE
              eddiemoney
              Here are the results with those last suggested settings.
              • eddiemoneyE
                eddiemoney
                I'll keep adjusting until i am doing this the right way with the right settings but in the interim, for this current project which i am trying to finish within the hour πŸ˜„ - why does this happen (attached)?
                The slightest change in color or multiplier (value of 1) turns the color white. I know I have had previous projects where the value was 30 or even 100 and had a perfect glow to it and maintained its color, didnt change to pink or white... something must be different that I am not noticing.
                • eddiemoneyE
                  eddiemoney
                  Look... it reflects the correct color and intensity but no matter what i try, it emits the bright white 😍
                  • andybotA
                    andybot
                    sorry - I don't usually use scalar for my units. I typically use luminous power. For the camera settings I gave you, you can use 10000 for the spotlight power. Then for a purple emmissive material, you can use an intensity of about 0.5 The brighter the intensity, the more pink it will look. May need to set the shutter slower, like 15
                    Also, try adding a radius of 3.0 to your spotlight for softer shadows, and increase the subdivs for the spotlights to something like 16 or 24.
                    Hope that helps.
                    • eddiemoneyE
                      eddiemoney
                      thanks! will try and report back
                      • andybotA
                        andybot
                        I took a stab at some settings since I am working on a similar sort of setup (spotlights on an object) and looked at what values would work for the lighting and material. Here is what I've got.
                        • eddiemoneyE
                          eddiemoney
                          closer but still very white.
                          let me check out your settings.
                          • eddiemoneyE
                            eddiemoney
                            with your settings
                            • eddiemoneyE
                              eddiemoney
                              i got frustrated and slammed the shutter speed up to 200 just to see what would happen and it actually came closer to my desired results. The problems now are there is less glow and I am guessing I will need a ton of spot lights to illuminate the scene now since it appears so dim. SO weird.
                              • andybotA
                                andybot
                                I think you just need to keep reducing the multiplier on the emmissive layer. It also helps to change the emmissive color to lower saturation and make it a darker value.
