    Structural Grid Component
    Scheduled Pinned Locked Moved Dynamic Components
    6 Posts 4 Posters 2.1k Views 4 Watching
      ArtPen
      Hey Guys,
      I am making a structural grid component.
      My grid lines are repeated by a COPY command inside component attributes .
      Just wondering is there a way to insert letters and numbers into grid markers.
      • 1, 2, 3, 4, …. for horizontal lines
      • A, B, C, D …. for vertical
      So every COPY of a grid will have next number or letter.
      Cheers
        ArtPen
        Thought image will help....
        • utilerU Offline
          utiler
          Not that I know if, mate. I've done up a simple SU file containing grids that I can insert and use for each job.
          What is the centrerline you've drawn there?
          purpose/expression/purpose/....
          • sdmitchS Offline
            sdmitch
            @artpen said:
            Hey Guys,
            Cheers
            Doubtfully the answer to your question but may give you an idea.
            mod = Sketchup.active_model
            ent = mod.active_entities
            sel = mod.selection
            ci=sel.first; ci.make_unique
            ents=ci.definition.entities
            p0=ci.bounds.corner(2).transform ci.transformation.inverse
            width=ci.bounds.width
            height=ci.bounds.height
            number='1'; dist=0; inc=24
            0.upto(width/inc) do
             p1=p0.offset(X_AXIS,dist)
             p2=p1.offset(Y_AXIS,-height)
             ents.add_cline(p1,p2)
             ents.add_text(number,p1.offset(Y_AXIS,6))
             number = number.next
             dist += inc
            letter='A';dist=0;inc=24
            0.upto(height/inc) do
             p1=p0.offset(Y_AXIS,-dist)
             p2=p1.offset(X_AXIS,width)
             ents.add_text(letter,p1.offset(X_AXIS,-6))
             letter = letter.next
             dist += inc
            http://sdmitch.blogspot.com/
            • PixeroP Offline
              Pixero
              Thats great. Can you make it work with millimeter?
              • sdmitchS Offline
                sdmitch
                I would assume so.
