    [Plugin] s4u_LineTool
    18 Posts 6 Posters 25.2k Views 6 Watching
    • B
      bsfranza
      hi there,
      if you could make the axis constraints work like in the normal su line tool that would be cool. i mean if one hits the up arrow the line is constrained on the blue axis and so on..
      also the "preview" (line gets thick) if i hit the shift key - like in the normal su line tool would be nice 😃
      other than that - great addition - a lovely thanks for giving it to us
      • hdpvH
        hdpv
        I had updated lock axis by Arrow ,try again!
        Suforyou
        http://www.sketchupforyou.com
          What is the tool at 0.17 ? (video first post)
          • hdpvH
            hdpv
            Hi Pilou!
            It's s4u_make box
            http://extensions.sketchup.com/en/content/s4u-make-box
            Suforyou
              Thx for the info! 😎
              It's always amazing to make fractal volumes in 3 seconds with your crazzy SU4 to Components! 😎
              http://moiscript.weebly.com/uploads/3/9/3/8/3938813/9562508_orig.gif
              • hdpvH
                hdpv
                imagine! like spaceship 😄
                Suforyou
                • G
                  glro
                  @hdpv said:
                  S4u Line Tool v1.0.0
                  Draw line from 2 points
                  Input length with Simple Function (+ ,-,,/) ex: 2m3 + 10m/4 + 3m
                  Snap points: 1/3 Line ,2/3 Line , Center Face...
                  http://extensions.sketchup.com/en/content/s4u-linetool
                  http://sketchucation.com/pluginstore?pln=s4u_LineTool
                  Video:
                  additions and other operations don't work when unit is meter?
                  • hdpvH
                    hdpv
                    It's work ok in meter units
                    Suforyou
                    • G
                      glro
                      i notice on your video, that the unit (cm) follows the number; on my computer, no unit, only the number
                      i use meters
                      if i type a number in the VCB rectangle, sketchup understands it meters, OK
                      but if a type an addition of 2 numbers, the plugin undeerstands it in inches or something, because the distance is much smaller
                      maybe there is a parameter i missed...
                      • hdpvH
                        hdpv
                        Hi Glro!
                        This problem is decimal symbol in your PC.
                        I will fix it.
                        Suforyou
                        • G
                          glro
                          @hdpv said:
                          Hi Glro!
                          I will fix it.
                          yes
                          you fixed it
                          thank you! big improvement for all french keyboard users...
                          you plugin is much better than the native line tool now...
                          • cottyC
                            cotty
                            Nice plugin. Have you thought about adding more snap point, golden ratio for example?
                            my SketchUp gallery
                            • hdpvH
                              hdpv
                              @Cotty : It's possible.
                              Suforyou
                              • G
                                glro
                                snap to 1/4 would be nice too
                                • hdpvH
                                  hdpv
                                  Snap 1/4 nearby 1/3,it's not good for quick select.Other,1/4 same 2 times middle
                                  Suforyou
                                    French Version 😉
                                    PS Another time, the Tool Bar don't appear after the translation! 😲
                                    (icon was present before the translation! Of course Tool Bar is enabled in the Tool bar Menu!)
                                    fr.zip
