    [Plugin] s4u_LineTool
    18 Posts 6 Posters 25.2k Views 6 Watching
    • hdpvH
      hdpv
      S4u Line Tool v1.2.1
      New feature : (request by Glro)
      -Draw Construction Lines
      -Fix bug for PC use Decimal Symbol ','
      French by Pilou :
      fr.zip
      S4u Line Tool v1.0.0
      Draw line from 2 points
      Input length with Simple Function (+ ,-,,/) ex: 2m3 + 10m/4 + 3m
      Snap points: 1/3 Line ,2/3 Line , Center Face...
      http://extensions.sketchup.com/en/content/s4u-linetool
      http://sketchucation.com/pluginstore?pln=s4u_LineTool
      Video:
      Suforyou
      http://www.sketchupforyou.com
      • pep75P
        pep75
        S u p e r! I really mis these simple functions in SU!!
        • B
          bsfranza
          hi there,
          if you could make the axis constraints work like in the normal su line tool that would be cool. i mean if one hits the up arrow the line is constrained on the blue axis and so on..
          also the "preview" (line gets thick) if i hit the shift key - like in the normal su line tool would be nice 😃
          other than that - great addition - a lovely thanks for giving it to us
          • hdpvH
            hdpv
            I had updated lock axis by Arrow ,try again!
            Suforyou
              What is the tool at 0.17 ? (video first post)
              • hdpvH
                hdpv
                Hi Pilou!
                It's s4u_make box
                http://extensions.sketchup.com/en/content/s4u-make-box
                Suforyou
                  Thx for the info! 😎
                  It's always amazing to make fractal volumes in 3 seconds with your crazzy SU4 to Components! 😎
                  http://moiscript.weebly.com/uploads/3/9/3/8/3938813/9562508_orig.gif
                  • hdpvH
                    hdpv
                    imagine! like spaceship 😄
                    Suforyou
                    • G
                      glro
                      Video:
                      additions and other operations don't work when unit is meter?
                      • hdpvH
                        hdpv
                        It's work ok in meter units
                        Suforyou
                        • G
                          glro
                          i notice on your video, that the unit (cm) follows the number; on my computer, no unit, only the number
                          i use meters
                          if i type a number in the VCB rectangle, sketchup understands it meters, OK
                          but if a type an addition of 2 numbers, the plugin undeerstands it in inches or something, because the distance is much smaller
                          maybe there is a parameter i missed...
                          • hdpvH
                            hdpv
                            Hi Glro!
                            This problem is decimal symbol in your PC.
                            I will fix it.
                            Suforyou
                            • G
                              glro
                              @hdpv said:
                              Hi Glro!
                              I will fix it.
                              yes
                              you fixed it
                              thank you! big improvement for all french keyboard users...
                              you plugin is much better than the native line tool now...
                              • cottyC
                                cotty
                                Nice plugin. Have you thought about adding more snap point, golden ratio for example?
                                my SketchUp gallery
                                • hdpvH
                                  hdpv
                                  @Cotty : It's possible.
                                  Suforyou
                                  • G
                                    glro
                                    snap to 1/4 would be nice too
                                    • hdpvH
                                      hdpv
                                      Snap 1/4 nearby 1/3,it's not good for quick select.Other,1/4 same 2 times middle
                                      Suforyou
                                        French Version 😉
                                        PS Another time, the Tool Bar don't appear after the translation! 😲
                                        (icon was present before the translation! Of course Tool Bar is enabled in the Tool bar Menu!)
                                        fr.zip
