    A problem with floor geneator SDM
    11 Posts 3 Posters 4.2k Views 3 Watching
      littleche
      HI
      floor generator canot prosess in this face and come this error :
      I want use wood sample . Where is the problem?
      FLOOR GENERATOR.skp
        You have a Texture Size (w,h) = 0! 😉
          littleche
          thanks pilou
          but I problem with wood patern ! you test this face with wood patern ?
          tile patern work without texture size set ...
          be like this photo :
          • sdmitchS Offline
            sdmitch
            @littleche said:
            HI
            [attachment=0:2gx0xiui]<!-- ia0 -->Untitled.jpg<!-- ia0 -->[/attachment:2gx0xiui]
            [attachment=1:2gx0xiui]<!-- ia1 -->FLOOR GENERATOR.skp<!-- ia1 -->[/attachment:2gx0xiui]
            I need the model in SU2014 in order to view it.
            Usually this occurs when tiny edges are created at the margin. I see you have corner selected as the grid origin. Have you tried using the center option? Which corner are you picking?
            http://sdmitch.blogspot.com/
              Sorry non problem for me! 🤓 (2015)
              Put same number of size wanted in the material editor and Texture Floor Parameters (w,h) as shown above! 🤓
              Kill or move the Z fighting surface working and you will obtain your wanted result! 😄
                littleche
                hi sdmith
                i save as this file su 2008 :
                FLOOR GENERATOR.skp
                I tried use the center option and i clean this face with cleanup and inspect with edge tools and have not any tiny edge . 😞 What other suggestions do you have?
                Hi pilou . your photo shows tile patern ! i have problem with wood patern .
                You can tell us more about these?:
                • sdmitchS Offline
                  sdmitch
                  hi sdmith
                  Is this what you wanted to do?
                  FLOOR GENERATOR.skp
                    littleche
                    yes!
                    How did you do?
                    • sdmitchS Offline
                      sdmitch
                      @littleche said:
                      yes!
                      How did you do?
                      There is a "bug" in the current version that is prone to have this error when 45 rotation is used. It doesn't always fail.
                      I'm hoping to corrected and updated version soon.
                        Sorry what is the Wood Patern?
                        It's just this 😄
                        http://s6.postimg.org/69m124jbl/kill_or_move.gif
                          littleche
                          @sdmitch said:
                          @littleche said:
                          yes!
                          How did you do?
                          thanks sdmitch .
                          You and other SU plug-in developers Are very, very dear For me and other Members sketch up .
                          I wish you all good luck ...
                          thanks again ...
