A problem with floor geneator SDM
HI
floor generator canot prosess in this face and come this error :
I want use wood sample . Where is the problem?
You have a Texture Size (w,h) = 0!
thanks pilou
but I problem with wood patern ! you test this face with wood patern ?
tile patern work without texture size set ...
be like this photo : -
@littleche said:
HI
[attachment=0:2gx0xiui]<!-- ia0 -->Untitled.jpg<!-- ia0 -->[/attachment:2gx0xiui]
[attachment=1:2gx0xiui]<!-- ia1 -->FLOOR GENERATOR.skp<!-- ia1 -->[/attachment:2gx0xiui]
I need the model in SU2014 in order to view it.
Usually this occurs when tiny edges are created at the margin. I see you have corner selected as the grid origin. Have you tried using the center option? Which corner are you picking?
Sorry non problem for me!
(2015)
Put same number of size wanted in the material editor and Texture Floor Parameters (w,h) as shown above!
Kill or move the Z fighting surface working and you will obtain your wanted result! -
hi sdmith
i save as this file su 2008 :
I tried use the center option and i clean this face with cleanup and inspect with edge tools and have not any tiny edge .
What other suggestions do you have?
Hi pilou . your photo shows tile patern ! i have problem with wood patern .
You can tell us more about these?:
hi sdmith
Is this what you wanted to do?
yes!
How did you do?
@littleche said:
yes!
How did you do?
There is a "bug" in the current version that is prone to have this error when 45 rotation is used. It doesn't always fail.
I'm hoping to corrected and updated version soon.
Sorry what is the Wood Patern?
It's just this
@sdmitch said:
@littleche said:
yes!
How did you do?
thanks sdmitch .
You and other SU plug-in developers Are very, very dear For me and other Members sketch up .
I wish you all good luck ...thanks again ...
