    Searching for a slice tool
    4 Posts 3 Posters 554 Views 3 Watching
    • jojo9J Offline
      jojo9
      i really like to slice up my models, unfortunately the default Sketchup method shows solids how they are: hollow inside. Which isn't really helpful, in reality things are different. šŸ˜„
      So my question here is, if somebody knows a plugin able to fill in with faces those edges cut by the slice plane of Su. Usually i did it manually, but I'm a bit tired to do it. I checked already several plugs, so the reason of my post.
        S4u_Slice ?
        http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=59170
          My Slicer does that ? [and more]
          http://sketchucation.com/pluginstore?pln=TIG_Slicer
          • jojo9J Offline
            jojo9
            Hi TIG,
            i found one of your (older?) plugins-SectionCutFace.rb
            Its excellent for my use! …and about your Slicer…speakless. As i like to work very much with carton… šŸ‘ šŸ‘
            With your input, this post could be even better šŸ’—
