    Missing in Action
    7 Posts 2 Posters 197 Views 2 Watching
    • O Offline
      orchard collie
      Hi from Darwin Australia
      Just experienced a weird problem with SU 2015. Suddenly found a timber texture has turned white on me.
      On getting into the group and questioning the material it shows as timber in the Entity Info box.
      Haven't done anything to edit the material, and am only using the default style Shaded with textures.
      Just brought in a timber barrel from the 3D Warehouse - shows woodgrain in Warehouse - changes to white when I place it in the model
      Any ideas?
      Orchard Collie
      • FrederikF Offline
        Frederik
        Are you sure it's a texture...?
        Could be an imported bitmap...
        Have you ensured that the Style you use in SU are shaded with texture...?
        Can you post a link to the 3D Warehouse model, allowing others to take a look at what's going on...?
        Cheers
        Kim Frederik
        • O Offline
          orchard collie
          Hi Kim
          Yes Shaded with Textures is on.
          Never posted a link to 3D rehouse before Any Tips?
          • FrederikF Offline
            Frederik
            You can open 3dwarehouse in a browser of your own choice...
            Locate the model and copy the URL and paste it here...
            Similar to this...
            https://3dwarehouse.sketchup.com/model.html?id=u45bdf41d-899e-4b10-907d-112609ef538c
            Cheers
            Kim Frederik
            • O Offline
              orchard collie
              Thanks Kim
              Here's the link to the component
              https://3dwarehouse.sketchup.com/model.html?id=6939f129249ada544293529704725d98
              Have opened it in a new SU file and it works fine - textures don't disappear at all.
              So… I suspect something is wrong with my SketchUp working file (86mb)
              Maybe I should contact SketchUp Support and see if they have any solution?
              Regards
              Orchard
              • O Offline
                orchard collie
                HI Kim
                Just renewed my Support and downloaded and installed the latest version of SU and all the missing materials have turned up!
                So panic over and End of Post
                (Hopefully)
                Cheers
                • FrederikF Offline
                  Frederik
                  Happy you got it solved... 👍
                  Cheers
                  Kim Frederik
