    [Plugin] Snapshot – (1.0.1) — updated 09.10.2012
    74 Posts 12 Posters 59.5k Views 12 Watching
    • JClementsJ Offline
      JClements
      Hi A:
      When the settings dialog opens, it does not extend downward enough to reveal the Cancel and OK buttons. I could not figure out why my setting changes were being ignored until I manually dragged the bounds of the dialog.
      Also, when unchecking the Ask Every Time option, it would not take until closing and reopening SketchUp.
      Regards, John
      Cancel and OK buttons are not shown
        Aerilius
        Thanks for reporting. The toolbar buttons took the settings from the moment when they were created (when SketchUp starts). That should be fixed now in version 1.0.2.
        • simon le bonS Offline
          simon le bon
          @driven said:
          I've been having a look at 'less' cutting edge editor's to see if I can get enough usable feature on a PC version.
          I'll PM the volunteers Giro + simon to test the basic concept using hard linked files with this template....
          About a week without any participation, I'm sorry. I'm always busy by waves.. Shall test and read the news this week end.
          ++simon
            glro
            i posted a message with some code related to your plugin ae snapshot.rb
            http://sketchucation.com/forums/viewtopic.php?f=323&t=39304&p=436887#p436887
            your plugin creates automatically a thumbnail and file shortcut to the model that is being created
            what i needed was the same functions, but for already existing models
            In the batch procedure i adapted from JF's code, the skp file is saved, and this triggers automatically aesnapshot.rb and creates the files in the specified folder
            when looking for a model, you just have to go to this folder
            Now, it is not completely finished:
            the prompt between each files is not convenient
            would be better to look for skp files in all subfolders too...
            i am working on it
              JClements
              Thank You A:
              The dialog is now larger and the top two-thirds of the buttons are visible; good enough to see and use.
              Regards, John
                Tokador
                It looks good. I'll try it.
                  Pherim
                  Hey, I don't know whether you take requests, but if you don't mind, I have one:
                  I would like to be able to disable Anti-Aliasing on the exported image, as is possible when exporting an image directly via sketchup. I want to export images with transparency without anti-aliasing, it would be great if this could be done.
                    Aerilius
                    This would need a little change (that even you could do if you like) to set the write_image option antialias => false. This rather old and complex plugin consists mainly of a plethora of options because every user could want something slightly different. Instead, you could also use Toolbar Editor.
                    [off:c47o1jic]%(#BF0000)[This plugin is superseded by the extension "Toolbar Editor".
                    It allows to create your own toolbar buttons for whatever function you want, in exactly the way you want.
                    You can achieve the snapshot function by pasting into the code field:]
                    filepath = UI.savepanel
                    view = Sketchup.active_model.active_view
                    keys = {
                      ;filename => filepath,
                      ;width => view.vpwidth,
                      ;height => view.vpheight,
                      ;antialias => true,  # or false
                      ;compression => 0.9, # Only for jpeg
                      ;transparent => true # Only for png
                    view.write_image(keys)
                    [/off:c47o1jic]
                    • robertWanR Offline
                      robertWan
                      I miss the window that will show a screen clipping.
                      Robert
                        Aerilius
                        The original plugin was not able to do a screen clipping/cropping. When SketchUp exports images of the current view, they always include the whole viewport. But you can set the pixel dimensions of the image.
                        If someone really needs all the options of the original plugin, it is still downloadable. Otherwise you create a toolbar button with a code snippets using ToolbarEditor. This is much easier to support, and it is easier to adapt to your specific needs.
                        This snippet asks for the file name and image dimensions. If you choose a filename with png or tif, the image will have transparency.
                        model = Sketchup.active_model
                        view = model.active_view
                        ro = model.rendering_options
                        filepath = UI.savepanel("Save Image File", nil, "BMP|*.bmp;|JPG|*.jpg;*.jpeg|PNG|*.png|TIF|.*tif;*.tiff|TGA|*.tga||")
                        width, height = UI.inputbox(
                          ["width", "height"],
                          [view.vpwidth, view.vpheight],
                          "Size of the screenshot")
                        unless filepath.nil? || width.nil? || height.nil?
                          is_transparent = filepath[/\.(png|tiff?)$/i]
                          if is_transparent
                            drawGround, ro["DrawGround"] = ro["DrawGround"], false
                            drawHorizon, ro["DrawHorizon"] = ro["DrawHorizon"], false
                          keys = {
                            ;width => width,
                            ;height => height,
                          begin
                            raise unless view.write_image(keys)
                            Sketchup.status_text = "A snapshot has been saved as #{filepath}."
                          rescue Exception => e
                            Sketchup.status_text = "Failed to save snapshot to #{filepath}. #{e.message}"
                          if is_transparent
                            ro["DrawGround"] = drawGround
                            ro["DrawHorizon"] = drawHorizon
                        • 4 / 4
