    [Plugin] Snapshot – (1.0.1) — updated 09.10.2012
    74 Posts 12 Posters 61.0k Views 12 Watching
      driven
      Hi giro,
      good you got that far, shame it's not all working...
      if you hover over or click on the "Placeholder text", do you get the resize handles[six green squares]?
      if not there's a simpler version in the folder to test the other bits...
      first test- can you open dragresize_iConEdit.html in a Browser [ IE, Chrome ] just to see if more works there.
      second test- open demo_Icon.html [it's in the same folder] in your Browser and swap the name in the 'ruby to test in SU...
      all the 'opacity' settings appear to not work, the toolbar hiding and the transparent SU logo.
      in either the html if you 'comment out' the first background to look like this and reload you should see the fireman!!!
      <body>
      <!--  <div class="SketchUp"></div> -->
      if not, it may be because that files name is in 'Cyrillic', change it to fireman_3 on the file and in the html reference
       background; url(ae_snapshot_images/ØÆ¶†‡≠Ω_3.png) no-repeat;
      to
       background; url(ae_snapshot_images/fireman_3.png) no-repeat;
      I'll modify the settings to hide the 'nicEditor' on a button.
      thanks for testing
        glro
        @driven said:
        Hi giro,
        yes i can resize the handles, both in sketchup and in chrome
        and i realize now that the menu in the html window is activ, but only once... the first time.
        if i close it and open it again, it is not active anymore.
        If i close sketchup and reload the plugin, it depends...
        What would be the next step: "file://" ? what is expected by the program at this point?
          driven
          the target for it appearing is very small [a 10px strip above the edit area... might be that]
          shouldn't need to close SU, can you right click 'Reload' on the 'WebDialog' to reload the html only?
          you need to type or drag'n'drop an image path onto it.
          But that's just for extra 'logo type' images, the "firemen image" should be there already. try 'commenting' out the "Sketchup div" to see it.
          I'm just trying a simpler version to click a button for the menu...
          [highlight=#80ff80:17yzd2rt]EDIT: I forgot to add this to the Sketchup css class in the html file,
          Add it and you should see two backgrounds
              zoom;1;
              filter; alpha(opacity=0);
          [/highlight:17yzd2rt]
            driven
            I did an update of a few things that might help,,,
            add the html to the iConEdit folder in plugins and replace the nicEdit.js in the nicEdit folder.
            cheers
            hover right hand corners and click SU button to show/hide toolbars
              glro
              i added the html to the iConEdit folder in plugins and replaced the nicEdit.js in the nicEdit folder.
              i didn't add the text in the css section, because i don't know where to add it exactly
              it doesn't help...
              i get 2 errors messages
                driven
                @glro said:
                it doesn't help...
                oops,I missed a step,,, your ruby file needs to point to /iConEdit/test_3_iConEdit.html
                the nicEdit.js error on line 169 character 2 is a tab and unchanged, I only tidied up the text sizes and the color picker, so revert to the other if you still have the error.
                  glro
                  @driven said:
                  @glro said:
                  it doesn't help...
                  i came back to the previous version of nice edit.js and i changed the html file name
                  now the html windows opens normally
                  i realised that i have to click on "placeholder text" to make active the menu above; but still, i get an error message
                  i click "si" and if i type the image address, it appears in the html windows, but it doesn't fit ...
                  nothing is simple...
                    driven
                    giro,
                    type in C:/Archivos de programa/Google/ SketchUp 8/Plugins/iConEdit/logo_images/site_logo.png
                    and see what happens...
                    post a screenshot
                      glro
                      hi
                      I typed "C:/Archivos de programa/Google/ SketchUp 8/Plugins/iConEdit/logo_images/site_logo.png" in the "add/edit image" URL dialogue box
                      i got this
                      • JClementsJ Offline
                        JClements
                        Hi A:
                        When the settings dialog opens, it does not extend downward enough to reveal the Cancel and OK buttons. I could not figure out why my setting changes were being ignored until I manually dragged the bounds of the dialog.
                        Also, when unchecking the Ask Every Time option, it would not take until closing and reopening SketchUp.
                        Regards, John
                        Cancel and OK buttons are not shown
                          Aerilius
                          Thanks for reporting. The toolbar buttons took the settings from the moment when they were created (when SketchUp starts). That should be fixed now in version 1.0.2.
                          • simon le bonS Offline
                            simon le bon
                            @driven said:
                            I've been having a look at 'less' cutting edge editor's to see if I can get enough usable feature on a PC version.
                            I'll PM the volunteers Giro + simon to test the basic concept using hard linked files with this template....
                            About a week without any participation, I'm sorry. I'm always busy by waves.. Shall test and read the news this week end.
                            ++simon
                              glro
                              i posted a message with some code related to your plugin ae snapshot.rb
                              404 Not Found
                              (sketchucation.com)
                              your plugin creates automatically a thumbnail and file shortcut to the model that is being created
                              what i needed was the same functions, but for already existing models
                              In the batch procedure i adapted from JF's code, the skp file is saved, and this triggers automatically aesnapshot.rb and creates the files in the specified folder
                              when looking for a model, you just have to go to this folder
                              Now, it is not completely finished:
                              the prompt between each files is not convenient
                              would be better to look for skp files in all subfolders too...
                              i am working on it
                                JClements
                                Thank You A:
                                The dialog is now larger and the top two-thirds of the buttons are visible; good enough to see and use.
                                Regards, John
                                  Tokador
                                  It looks good. I'll try it.
                                    Pherim
                                    Hey, I don't know whether you take requests, but if you don't mind, I have one:
                                    I would like to be able to disable Anti-Aliasing on the exported image, as is possible when exporting an image directly via sketchup. I want to export images with transparency without anti-aliasing, it would be great if this could be done.
                                      Aerilius
                                      This would need a little change (that even you could do if you like) to set the write_image option antialias => false. This rather old and complex plugin consists mainly of a plethora of options because every user could want something slightly different. Instead, you could also use Toolbar Editor.
                                      [off:c47o1jic]%(#BF0000)[This plugin is superseded by the extension "Toolbar Editor".
                                      It allows to create your own toolbar buttons for whatever function you want, in exactly the way you want.
                                      You can achieve the snapshot function by pasting into the code field:]
                                      filepath = UI.savepanel
                                      view = Sketchup.active_model.active_view
                                      keys = {
                                        ;filename => filepath,
                                        ;width => view.vpwidth,
                                        ;height => view.vpheight,
                                        ;antialias => true,  # or false
                                        ;compression => 0.9, # Only for jpeg
                                        ;transparent => true # Only for png
                                      view.write_image(keys)
                                      [/off:c47o1jic]
                                      • robertWanR Offline
                                        robertWan
                                        I miss the window that will show a screen clipping.
                                        Robert
                                          Aerilius
                                          The original plugin was not able to do a screen clipping/cropping. When SketchUp exports images of the current view, they always include the whole viewport. But you can set the pixel dimensions of the image.
                                          If someone really needs all the options of the original plugin, it is still downloadable. Otherwise you create a toolbar button with a code snippets using ToolbarEditor. This is much easier to support, and it is easier to adapt to your specific needs.
                                          This snippet asks for the file name and image dimensions. If you choose a filename with png or tif, the image will have transparency.
                                          model = Sketchup.active_model
                                          view = model.active_view
                                          ro = model.rendering_options
                                          filepath = UI.savepanel("Save Image File", nil, "BMP|*.bmp;|JPG|*.jpg;*.jpeg|PNG|*.png|TIF|.*tif;*.tiff|TGA|*.tga||")
                                          width, height = UI.inputbox(
                                            ["width", "height"],
                                            [view.vpwidth, view.vpheight],
                                            "Size of the screenshot")
                                          unless filepath.nil? || width.nil? || height.nil?
                                            is_transparent = filepath[/\.(png|tiff?)$/i]
                                            if is_transparent
                                              drawGround, ro["DrawGround"] = ro["DrawGround"], false
                                              drawHorizon, ro["DrawHorizon"] = ro["DrawHorizon"], false
                                            keys = {
                                              ;width => width,
                                              ;height => height,
                                            begin
                                              raise unless view.write_image(keys)
                                              Sketchup.status_text = "A snapshot has been saved as #{filepath}."
                                            rescue Exception => e
                                              Sketchup.status_text = "Failed to save snapshot to #{filepath}. #{e.message}"
                                            if is_transparent
                                              ro["DrawGround"] = drawGround
                                              ro["DrawHorizon"] = drawHorizon
                                          • 4 / 4
