    Visualizer for SketchUp
    extensions
    157 Posts 37 Posters 142.5k Views 37 Watching
    • W Offline
      willanie
      Hi Driven,
      Interesting suggestions, but I don't think they are a better workaround then rendering Visualizer twice.
      In fact, making an alpha channel outside of Visualizer may result in some edge mismatch.
      The creation of the alpha channel in Visualizer was refined to the point where compositing in paint software like Gimp or Photoshop works without any edge fringing.
      willanie
        driven
        the color by layer ones is a Visualizer export...
        Layer setting 'Color by Layer'
        Vis setting export png trans background...
        re-done as I hadn't locked to SU...
        only the window glass still shows...
        EDIT:
        this is color by layer, use view size 2d png export non-transparent bg...for comparison...
        • W Offline
          willanie
          Hi Driven,
          I didn't think of using color by layer set to black.
          Problem is, this mode doesn't effect the background sky in Visualizer.
          So you could get something like the attached image.
          Even if you use Visualizer a second time, as I suggested, could potentially result in edge fringing. Visualizer processes a saved image with alpha to minimize edge fringing and this would not happen in a de-speckled render.
          willanie
          • V Offline
            vidy
            @willanie said:
            Hi Driven,
            willanie
            Got it Willanie, thanks for your information
            Regards,
            VD
            still so much to learn..
              It's not a so hard work to render twice! πŸ˜‰
              • W Offline
                willanie
                An example of Visualizer1.3 enhanced mode.
                This mode can often result in very bright single pixels also known as "fireflies" caused by an extremely bright light source like the sun.
                The despeckle noise reduction feature is there to help remove them.
                The back wall in this scene is assigned a material with a name that includes the word "mirror" for sharp reflections.
                • pbacotP Offline
                  Thanks for the notes Wilanie
                  • V Offline
                    vidy
                    Nice one Willanie..
                    • W Offline
                      willanie
                      another example ... this one took about 35 minutes to render on my desktop
                      a couple of the fireflies weren't removed by the despeckle mode but it still looks pretty nice
                      • cottyC Offline
                        cotty
                        Yes, very nice!
                        πŸ‘
                        my SketchUp gallery
                        • pbacotP Offline
                          I looked at the enhanced material settings. Which is best for car paint? The metal settings are too metallic. Plastic doesn't quite make it.
                            driven
                            you can link them together for different effects e.g. shiny_plastic, shiny-tile...
                            • Mike LuceyM Offline
                              Mike Lucey
                              I've been using Visualizer since it first launched. It suits me as I'm not really into spending any time on producing renders. I was disappointed when they announced that they would not be further developing the application but at least they made the current version free to use.
                              A couple of days ago I came across AmbientOcclusion for SketchUp http://www.ambientocclusion-sketchup.com
                              Its much like Visualizer, couple of clicks and after a few minutes you have a render. It also offers the option of rendering in the SketchUp viewport which I rather like as against rendering in a window. After seeing the first in-viewport render I thought that Trimble SketchUp should buy this app and include it in SketchUp Pro ........ just a thought. It definitely would distance SketchUp Pro from SketchUp Make!
                              There are two versions of AmbientOcclusion, Lite at $39 which only produces mono renders and Pro at $89 that does color, textures and depth-of-field effects.
                              Its expensive when compared to Visualizer, originally at $20 and now free, but I think the output quality is far superior to Visualizer in far less time, just a few minutes for me in most cases, quite impressive.
                              I have emailed the developers and they advise that they have lighting among other features on the 'to do' list. Hopefully they will keep improving the plugin without making it bloated.
                              Here is a Visualizer and AmbientOcclusion render of a little project I'm working on. Both renders were done in around 3 minutes and I spent zero time fiddling around with settings.
                              Vizualizer Output
                              AmbientOcclusion Output
                              • W Offline
                                willanie
                                I do like the added shape detail provided by the ambient occlusion shading. Can you get reflections?
                                • pbacotP Offline
                                  Thanks, I thought so but I wasn't sure it was doing anything. I'll experiment more. I need reflections for exterior shots. I'd like to see more AO than Visualizer but not quite happy with what I see in the AO 4 SU app. If I want to spend more time, I go to Twilight.
                                  BTW with the poor materials window on Mac Sketchup, it is still slow and tedious just to change material names to try different effects.
                                    Mike Lucey
                                    I think so Will. Attached is an image from the AO site which shows reflections. I have not tried it out yet.
                                      For SU 2016 (Visualizer yet installed on SU 2015)
                                      Installation don't work directly ! 😲
                                      (I suppose that is working directly if Visualizer don't yet installed!)
                                      A little trick! (For Windows 8.1 - I don't know Mac's world! )
                                      Make this new folder Plugins (don't existing because 2016 is new and empty)
                                      and copy past from the ProgramData / SU 2015:
                                      Folder ImaginationVisualizer and file ImaginationVisualizer.rb
                                      That's all! πŸ€“
                                      You must have that! πŸ˜„
                                      Works like a charm! 😎 And works in duplication 2015 2016 ! πŸ€“
                                        driven
                                        on a mac just move /copy the folder and file into the User plugin folder and it works fine...
                                        • W Offline
                                          willanie
                                          Great! ... I was wondering if making it work for 2016 was as easy as that.
                                          thanks
                                          • pbacotP Offline
                                            Has anyone had luck with pool water for enhanced materials? With a texture you get ripples, but the pool water only comes out very dark blue for me, not good for swimming pools. "Water" texture under NON enhanced textures looks OK but no ripples.
                                            • 4 / 8
