    Visualizer for SketchUp
    extensions
    157 Posts 37 Posters 137.5k Views 37 Watching
      driven
      you can link them together for different effects e.g. shiny_plastic, shiny-tile...
      • Mike LuceyM Offline
        Mike Lucey
        I've been using Visualizer since it first launched. It suits me as I'm not really into spending any time on producing renders. I was disappointed when they announced that they would not be further developing the application but at least they made the current version free to use.
        A couple of days ago I came across AmbientOcclusion for SketchUp http://www.ambientocclusion-sketchup.com
        Its much like Visualizer, couple of clicks and after a few minutes you have a render. It also offers the option of rendering in the SketchUp viewport which I rather like as against rendering in a window. After seeing the first in-viewport render I thought that Trimble SketchUp should buy this app and include it in SketchUp Pro ........ just a thought. It definitely would distance SketchUp Pro from SketchUp Make!
        There are two versions of AmbientOcclusion, Lite at $39 which only produces mono renders and Pro at $89 that does color, textures and depth-of-field effects.
        Its expensive when compared to Visualizer, originally at $20 and now free, but I think the output quality is far superior to Visualizer in far less time, just a few minutes for me in most cases, quite impressive.
        I have emailed the developers and they advise that they have lighting among other features on the 'to do' list. Hopefully they will keep improving the plugin without making it bloated.
        Here is a Visualizer and AmbientOcclusion render of a little project I'm working on. Both renders were done in around 3 minutes and I spent zero time fiddling around with settings.
        Vizualizer Output
        AmbientOcclusion Output
        • W Offline
          willanie
          I do like the added shape detail provided by the ambient occlusion shading. Can you get reflections?
          • pbacotP Offline
            Thanks, I thought so but I wasn't sure it was doing anything. I'll experiment more. I need reflections for exterior shots. I'd like to see more AO than Visualizer but not quite happy with what I see in the AO 4 SU app. If I want to spend more time, I go to Twilight.
            BTW with the poor materials window on Mac Sketchup, it is still slow and tedious just to change material names to try different effects.
              Mike Lucey
              I think so Will. Attached is an image from the AO site which shows reflections. I have not tried it out yet.
                For SU 2016 (Visualizer yet installed on SU 2015)
                Installation don't work directly ! 😲
                (I suppose that is working directly if Visualizer don't yet installed!)
                A little trick! (For Windows 8.1 - I don't know Mac's world! )
                Make this new folder Plugins (don't existing because 2016 is new and empty)
                and copy past from the ProgramData / SU 2015:
                Folder ImaginationVisualizer and file ImaginationVisualizer.rb
                That's all! πŸ€“
                You must have that! πŸ˜„
                Works like a charm! 😎 And works in duplication 2015 2016 ! πŸ€“
                  driven
                  on a mac just move /copy the folder and file into the User plugin folder and it works fine...
                  • W Offline
                    willanie
                    Great! ... I was wondering if making it work for 2016 was as easy as that.
                    thanks
                    • pbacotP Offline
                      Has anyone had luck with pool water for enhanced materials? With a texture you get ripples, but the pool water only comes out very dark blue for me, not good for swimming pools. "Water" texture under NON enhanced textures looks OK but no ripples.
                      • W Offline
                        willanie
                        Hi pbacot,
                        You can use a png image with an alpha channel that is less than 1.0 or 255
                        Here is an example.
                        • pbacotP Offline
                          Thanks! So the trick is the texture?
                            http://getvisualizer.com/blog/glass-water-and-reflections.html πŸ˜‰
                            http://visualizervf.weebly.com/uploads/1/3/5/4/13544449/583359052.jpg
                              And with the 2016 it's very more easy because there are some new Materials !!! πŸ˜‰
                              So nothing to do! 😎
                                Nothing to do, just wait 10 secondes for undarkness! πŸ˜„
                                So you can re-import it in the 2015 and render if needing! πŸ˜„
                                WIth Ivy πŸ˜‰
                                • pbacotP Offline
                                  Thanks Pilou! That might make DL 2016 worthwhile. (I have to update Mac OS--2016 does not work on Lion I think.)
                                  • F Offline
                                    frankwil
                                    Can anyone expound on getting Visualizer to work in Sketchup 2016 for Mac OS X? I'm seeing no plugins, or folders for that matter, anywhere inside Sketchup 2015 that I can identify as belonging to visualizer, though I know it's there and is working for that version of SU. My problem is that I've just drawn some fairly complex models in SU 2016, but can't get visualizer to work after a normal install, and don't want to have to recreate them in SU 2015.
                                    • jujuJ Offline
                                      juju
                                      Unfortunately I can't help with the earlier part of your query, but you should be able save the SU2016 file as a SU2015 file without any trouble at all, no need to recreate the model...
                                        beacharch
                                        How can I get the APP to work on Mac OS X? I saw the earlier post and saw no answer. How can I get to work?
                                        • W Offline
                                          willanie
                                          Hi beacharch
                                          This approach assumes you have already installed Sketchup2015 or Sketchup2014 and Visualizer.
                                          After installing Sketchup2016
                                          dont start Sketchup2016 yet and go to folder
                                          /Library/Application Support/
                                          If there isn't one already create this folder hierarchy(exactly matching upper and lowercase)
                                          /Library/Application Support/Sketchup 2016/Sketchup/Plugins
                                          from /Library/Application Support/Sketchup 2015/Sketchup/Plugins
                                          copy these two items(one is a folder the other is a ruby file)
                                          paste them into
                                          Now launch Sketchup2016 you should see Visualizer under the Extensions pull-down.
                                          If Visualizer doesn't show up in the Extensions pull-down
                                          click on
                                          Sketchup->Preferences->Extensions
                                          you should see Visualizer with an unchecked toggle box ... check that toggle on
                                          close the preferences window
                                          and Bob's your uncle Visualizer running in Sketchup2016
                                          (you may have to relaunch Sketchup)
                                            beacharch
                                            Thanks, that worked fine!
                                            • 4 / 8
