Sketchup pro 2015 create house model in 1.30 hour
Sketchup create house model in 1.30 hour
http://sketchucation.com/forums/viewtopic.php?f=18%26amp;t=60779 -
Good job! I like some of your modelling ideas for fast output!
Nice video!
Thank you for sharing.Some comments:
- I would suggest to orient the faces correct instead of painting them white only (e.g. for rendering?)
- It will probably be faster to use components instead of groups for the repetitive part (windows, doors, ...) ("edit one, paint all")
- For consecutive push pull action with the same distance, you can use a double click insread of searching an inference point
- For repeated copies, you can use the array functionality
thanks for your work
