    Sketchup pro 2015 create house model in 1.30 hour
    4 Posts 4 Posters 5.9k Views 4 Watching
      jones04
      Sketchup create house model in 1.30 hour
      http://sketchucation.com/forums/viewtopic.php?f=18%26amp;t=60779
      • pbacotP Offline
        Good job! I like some of your modelling ideas for fast output!
        • cottyC Offline
          cotty
          Nice video!
          Thank you for sharing.
          Some comments:
          • I would suggest to orient the faces correct instead of painting them white only (e.g. for rendering?)
          • It will probably be faster to use components instead of groups for the repetitive part (windows, doors, ...) ("edit one, paint all")
          • For consecutive push pull action with the same distance, you can use a double click insread of searching an inference point
          • For repeated copies, you can use the array functionality
          my SketchUp gallery
          • greatwallG Offline
            greatwall
            thanks for your work
