    I want to divide selected faces inputting numbers
    13 Posts 5 Posters 683 Views 5 Watching
      blackmonk75
      Hi~
      I want to divide selected faces inputting numbers of columns and rows.
      Please help me.
      I'm waiting for your replies.
      • sdmitchS Offline
        sdmitch
        @blackmonk75 said:
        Hi~
        Please help me.
        Divide Selected Faces.rb
        http://sdmitch.blogspot.com/
          For more complex Cuttings you have also the Split Tools by TIG! πŸ˜‰
          (here on the Left" "Split Sausage") (sorry for the "clipping screen" ! )
          And also this Splipt UP by Rich O Brien πŸ˜‰
            blackmonk75
            @sdmitch said:
            @blackmonk75 said:
            Hi~
            Please help me.
            Hi~
            Thank you...
            This is the very good plugin that I wanted.
            But error message show in sketchup 8.
            "Error Loading File Divide Selected Faces.rb
            undefined method 'file_loaded?' for main:Object"
            and I can't find the plugin on top menus.
            • sdmitchS Offline
              sdmitch
              @blackmonk75 said:
              @sdmitch said:
              @blackmonk75 said:
              Hi~
              Please help me.
              Hi~
              Thank you...
              Strange, I don't have a problem in SU8 and there is certainly nothing wrong with 'file_loaded?'. It is used in every plugin I have ever written.
              When successfully loaded, you will find it in the Plugins menu.
                blackmonk75
                @sdmitch said:
                @blackmonk75 said:
                @sdmitch said:
                @blackmonk75 said:
                Hi~
                Please help me.
                Hi~
                I remove the sketchup 8 and install.
                So the plugin is running good.
                Thank you very much.
                There was only one problem.
                The plugin run only 'Top View'.
                The plugin errors 'Front View' and other views.
                I'm sorry.
                Could you fix this error?
                • TIGT Online
                  The example .RB did NOT include require("sketchup.rb") near its start.
                  If it does not have that, then the file_loaded? test fails - at least with older SketchUp versions (like v8) [Tool's scripts like 'sketchup.rb' only load first in newer versions of SketchUp - side stepping the issue !].
                  If an earlier loading script has already done the 'require' then it'll work in any SketchUp version.
                  But if not, then in older versions it'll fail without an explicit 'require'.
                  • sdmitchS Offline
                    sdmitch
                    Oops, my bad on the require.
                    Front View? Now you tell me.
                      blackmonk75
                      I want to use this plugin besides top view in the all viewport.
                        blackmonk75
                        thank you...
                        I solved the problem.
                        I remove the sketchup 8 and re-install.
                        • sdmitchS Offline
                          sdmitch
                            blackmonk75
                            Dear Sdmitch.
                            Thank you very much for your help and kindness.
                            I'm really glad that I want to get the plugin.
                            Thanks to all of you.
                            • cottyC Offline
                              cotty
                              Very nice plugin, sdmitch! Thank you.
                              my SketchUp gallery
