    Executing one call_back executes another.
    12 Posts 6 Posters 1.1k Views 6 Watching
      We don't see you js or html... or most of your rb.
      So when is the callback "InitializeForm" called ?
      If it is called as the html is ready then if you reload the page after the "Select" button is clicked then that callback does re-run ?
      The values do default so I suspect something is reloading the page's html ?
      • sdmitchS Offline
        sdmitch
        "initializeForm" is called when the html is loaded but I am not knowingly doing anything that would cause the html to reload when the select button is clicked.
        Select by Attribute_WD.rb
        http://sdmitch.blogspot.com/
          driven
          have you got a link for the model?
          It has no values for the models I've tried, and it would be easier if we look at the same one...
          if you remove value="select" from the button attributes does it work correctly?
          • sdmitchS Offline
            sdmitch
            No change with value="select" removed.
            Here is the model provided to me that I have been testing with.
            scaffold with attributes_v14.skp
              In HTML the <script> code block normally goes in the <header>, NOT the <body> - try moving it into there and retest...
              As it is window.location='skp:InitializeForm@'; is run whenever the HTML body loads.
              Currently your code makes a new WebDialog for @dlg afresh every time your tool is run, perhaps adding unless @dlg after it would at least prevent that ?
              • sdmitchS Offline
                sdmitch
                Moving script to the header only caused the select list to remain empty. Adding the unless caused the InitializeForm to not run at all.
                Why InitializeForm is run every time a button is clicked is still a mystery for now. I have managed to overcome the problems that caused.
                  MSP_Greg
                  Remove the form tags. Forms have some odd default behavior, in this case, reloading the html...
                  Attached an rb file with some changes --
                  1. Uses 'html is loaded' for callback
                  2. Changed 'InitializeForm' execute_script statements to pass arrays
                  I did remove the top of the code.
                  Greg
                  Select by Attribute_WD 1.1.rb
                  • sdmitchS Offline
                    sdmitch
                    Greg
                    Greg, Thanks for help. It seems that the form tags were the majority of the problem.
                    • tt_suT Offline
                      tt_su
                      Did you make that buttom a Submit button? By default I think that will make a POST request to the same page it is on. You need to either capture that event and prevent the default action, or make the button a non-submit: <input type="button"> or <button></button>.
                      • sdmitchS Offline
                        sdmitch
                        No, I just removed the <form></form> and that fixed the "problem".
                          That would do the same thing - the <form> element usually have the URL to which to submit to. Without a parent <form> the submit button had no default action.
