    HiDef Rim Tutorial using Flowify
    10 Posts 6 Posters 6.6k Views 6 Watching
    • chippwaltersC Offline
      chippwalters
      A follow up to the Tire Tutorial, this shows how to use Flowify and Vertex Tools to create a rim for a tire.
      http://dl.dropboxusercontent.com/u/3788438/3D/TireTute/Rim.jpg
      Currently working with Cross-Reality technologies
      • cottyC Offline
        cotty
        Again a very nice video. Thank you!
        my SketchUp gallery
          chippwalters
          @pilou said:
          I see you use Solid Inspector and not Solid Solver: why ? πŸ˜„
          Fist don't fill a missing face, second yes! πŸ˜„
          I just got in the habit of using Solid Inspector. I like it. I'll check out Solid Solver too! Thanks for the tip.
          • pbacotP Offline
            excellent!
              First don't fill a missing face, second yes! πŸ˜„
                CAUL
                Again, very, very nice tutorial. I think there are two points in relation to Flowify that are worth mentioning.
                1) The thickness of the geometry (the dimension perpendicular to the projection grid) is transferred directly to target surface coordinates, the geometry is then transformed from there into world coordinates. So, if the target surface is in a scaled group the thickness will be scaled as it is transformed to world coordinates. For predictable results the target surface can be exploded and regrouped, this will put an identity transform (scale=1) on the target surface group. Ideally, Flowify should handle this but currently does not..
                2) The second point concerns the relation between the projection grid and the target surface. Flowify sets up a coordinate system between the grids where all cells have the exact same size in uv-space. As seen in the image below, the results are more predictable if the projection grid and target surface have more corresponding cell sizes. This can be achieved by either constructing a custom projection grid (Image 2) or by having about equal sized cells in the target surface (Image3). In regards to the tutorial, if you keep the idle points in the poly line and convert these into quads, then the regular grid (constructed with impose grid) will better match the target surface.
                • KrisidiousK Offline
                  Krisidious
                  Shared at my race car simulation forum.
                  http://isiforums.net/f/showthread.php/24899-SketchUp-Tire-Tutorial-using-Flowify
                  By: Kristoff Rand
                    chippwalters
                    Thanks for the advice. The problem with 'keeping the idle points' is that then one has to manually stitch up the resulting surface to create quads, which can take quite some time-- unless you know a way of automating quad generation on non-quad topology?
                    Check out the video at 3:25 where I confront this issue. If there are co-linear groupings of 3 or more vertices in the polyline, it will not generate a quad compatible surface. Any thoughts on how to automate quad generation during Follow-Me?
                    Thanks again for a GREAT tool!
                    • cottyC Offline
                      cotty
                      @chippwalters said:
                      A kind of automation in this case...
                      click to view animation
                      my SketchUp gallery
                        chippwalters
                        Thanks. Did not know about Split Tools.
