    Dimensioning with both mm and inch
    23 Posts 7 Posters 2.8k Views 7 Watching
    • KrisidiousK
      Krisidious
      When I first worked in SU I used Autocad to draft. Then after I think 2013 Layout came out I made the move to SU/Layout and I have not looked back. I never really dimensioned anything in SU... I found it clunky and unreliable. I often wished and still do, for a SU/Ruby drafting solution that could be more versatile than Layout and be open source for new ideas.
      By: Kristoff Rand
        Kristoff, the thing you should be looking forward to is more and better dimensioning tools in LO. That's the better place to be putting in dimensions.
        • KrisidiousK
          Krisidious
          Is it? I dream of nodes and auto-dimensioning (to an extent)... Smart dims that knew what we were doing, vertical, horizontal, 2D and 3D. Real symbol libraries and a direct connection to BIM info that doesn't have to have Layout open and go back and forth to check stuff as you go, not fix it work after modeling. Smart full vector hatches. This place has trained me to expect the impossible from Ruby and the Plugin Authors. Ok, back to Earth now... I think I flew too close to the Sun.
          By: Kristoff Rand
            If you look at where the development has been as far as dimensions are concerned, you'll nothing has changed in SU in years. In fact I don't think there's been any changes to it at least since before V3. LO has gotten many improvements though. I'm only guessing but I imagine we'll see other improvements in LO2016.
            There have been other improvements in text such as Auto Text which I leverage in every LO project, now. Most of the labels in that plan I posted the other day were auto-filled. Maybe we'll get radial dimensions and other cool stuff soon.
            • KrisidiousK
              Krisidious
              yeah I could handle anything really...
              By: Kristoff Rand
                swasacase
                I use dual dimensioning all the time. I'm just starting to use LO more frequently, and starting to get away from Turbocad. I hope the developers make a dual dimension tool. Dimensioning everything twice over is very time consuming
                Dual Dim Sample.pdf
                • sdmitchS
                  sdmitch
                  @auchifai said:
                  Recently I was requested by my client to put both mm and inch as the unit for all the dimensions. I tried to find some way to do it but eventually what I did is to use mm as the model unit and type all units in inch with 3D text. It works but of course it is not efficient. I just wonder if anyone knows how can I do it better? I am enclosing an image of my work here for your reference. Thanks!
                  [attachment=1:2hchdrnf]<!-- ia1 -->temp.png<!-- ia1 -->[/attachment:2hchdrnf]
                  mod = Sketchup.active_model
                  ent = mod.active_entities
                  txt = ent.grep(Sketchup;;DimensionLinear)
                  for t in txt
                   dim = (t.text.to_f/25.4).round(1)
                   t.text=t.text+"\n("+dim.to_s+"\")"
                  http://sdmitch.blogspot.com/
                    Cool! How hard to make it go the other way with metric in the parentheses?
                    • sdmitchS
                      sdmitch
                      units = Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]
                      for t in txt
                       case units
                        when 2
                        when 0
                         dim = (t.text.to_f*24.5).round(0)
                         t.text=t.text+"\n("+dim.to_s+"mm)"
                      • JQLJ
                        JQL
                        And is it very hard to put it in Sketchucation Plugin Store?
                        www.casca.pt
                        Visit us on facebook!
                        • sdmitchS
                          sdmitch
                          No, the hard part is trying to anticipate all the combinations of units that will be wanted.
                          A new version that is accessed through the Context Menu. What makes the most sense?
                          • KrisidiousK
                            Krisidious
                            Tig has written a dual dim tool for SU... does everyone here know that?
                            404 Not Found
                            (sketchucation.com)
                            By: Kristoff Rand
                            • 2 / 2
