    Resizing a component to exact mm?
    12 Posts 4 Posters 4.8k Views 4 Watching
      Yes, it is possible. If you know the x, y, and z dimensions, select the geometry of the light and get the Scale tool. Grab a corner scale handle and start to move it. It doesn't matter which direction. Let go of the mouse and type the desired dimensions in the form xmm,ymm,zmm and hit Enter. If you use the comma as a decimal separator, use semi colons as the separators. i.e. xmm;ymm;zmm You need to type the units so SketchUp knows you're after dimensions and not scale factors.
      Before you do the scaling, check the component's axis orientation. Red is x, green is y and blue is z.
      Note that normally, when you scale with a corner scale handle, the scale factor is equal in all three directions but it doesn't have to be. You could enter different scale factors for each direction if you wish.
        Brewer
        Thanks Dave, but that doesn't seem to work - if I grab a corner in the scale tool, for a start it is really hard to get it to 'stretch' in the right direction, and even when I do manage it, typing in (for example) "50mm" makes the whole component resize to something much much smaller than expected. It's almost like it is not recognising my input as mm, even though the model functions correctly (in mm) in every other way.
        Any idea what I'm doing wrong?
          How about sharing the component here?
          It sounds to me as if you didn't follow the directions I gave. "...typing in (for example) "50mm"..." isn't enough. You have to use the form I indicated before and type in all three values.
          If you can't get the scale handle to move where you want, you need to orbit. As I said before, it doesn't matter which direction you move that scale handle, just move it, let go over the mouse and type.
          • JQLJ Offline
            JQL
            You can also do it like this if you know a single dimension BETWEEN TWO POINTS of the component:
            • Edit the component (double click);
            • Make sure you're "inside" the component editing it (very important to be in the right context);
            • Use "Tape Measure" tool to get the distance between those two endpoints (it must really be two points);
            • The distance will show up on the Measurements box in the bottom right after you use the tool;
            • If you're seeing that distance, type the new distance you want (will show up on the Measurements box in the bottom right as you type) and hit return/enter.
            • Sketchup asks if you want to scale the component to the new size and you say yes. Take care because if you're not in the right context, sketchup will ask if you want to scale the whole model... and you might not want that!
            Hope this works
            NOTE: There are some spooky 3D Warehouse models that don't scale right with this tool, you might have to explode some of their parts until it works. Use outliner (Window > Outliner)to see the parts composing those components.
            www.casca.pt
            Visit us on facebook!
              But using the Tape Measure tool to do as you describe, JQL, scales all the dimensions proportionally which the OP already discovered and which he said he didn't want to do.
                Here's a quick example.
                I randomly drew the shape at left with the dimensions as shown, copied it to the right and scaled it as I described typing the desired dimensions as 100mm,40mm,200mm and hitting Enter.
                • BoxB Offline
                  And here's a moving version showing that you can input different types of measurements.
                    Thank you for making that animation, Box.
                    • JQLJ Offline
                      JQL
                      You're right
                      www.casca.pt
                        Brewer
                        Dave, you are absolutely right, I'm so sorry - I somehow missed the comma separated form you specified. That does exactly what I need - thank you kindly!
                          I'm happy you got it sorted.
