    SketchUp and KeyShot FOV and Focal Length don't match
    31 Posts 4 Posters 8.5k Views 4 Watching
      slbaumgartner
      Those warnings occur when you reload a Ruby that defines constants in its code. They won't happen if the code is written to allow for this possibility. However, in most cases the warnings have no effect and can safely be ignored. The final line saying "true" is your indicator that the load succeeded.
      • chippwaltersC
        chippwalters
        So then, what do I do next? Use the Keyshot plugin button to export the file? Will it use your script or it's script?
        Currently working with Cross-Reality technologies
          driven
          steve beat me to it but hi ho...
          there just warnings, because we overwrite the existing one for the SU session...
          the advantage of testing this way is it's immediate and if it doesn't work you just trash it...
          the old one will load again after a restart...
          if it does work, you can move it to the folder and rename the old one or trash it...
            driven
            it will use the last loaded script, i.e. my version...
            • chippwaltersC
              chippwalters
              Thanks.
              I did what you said, but the results weren't what was expected:
              1. ORIGINAL in SU (Focal Lenght 42mm, FOV 46.8 degrees)
              2. Using your plugin code. Note the FOV is different, but still not correct.
              3. ORIGINAL KS Plugin. Note the FOV is also different.
              http://dl.dropboxusercontent.com/u/3788438/3D/cameramapping4.jpg
                driven
                you want post the skp [or PM...]
                • chippwaltersC
                  chippwalters
                  Here's the SKP
                  https://dl.dropboxusercontent.com/u/3788438/3D/test.skp
                    driven
                    btw, so you know...
                    the only thing I change was a 'back up' for a SU shortfall
                     if cam_aspect == 0.0
                            cam_aspect = width/height.to_f.round(3)
                    I you don't have a Advanced camera set, SU sets the aspect ratio to 0.0, which is crazy...
                    this bit of code just tell KS to use 16:9 in that circumstance...
                    I'll have a look at your skp...
                    • chippwaltersC
                      chippwalters
                      @driven said:
                      btw, so you know...
                      >       end
                      Thanks again for your generous help.
                      I did look at your Ruby and saw that, and was wondering if there was anything else. I've written some Python scripts for Vue-Infinite, but don't know much about SU's api-- other than other plugins have figured this out-- and KS hasn't. I believe they first mentioned to me SU didn't have the correct api hooks to get an accurate camera from. That's when I mentioned all the other renderers have figured it out. They said they would take a look at it. Last time they said they'd work on the SU plugin it took them 2 years.
                      Too bad Thea and Vray are so damn slow compared to Keyshot. Of course, they both can do a lot more too!
                      Fwiw, here's an interior shot modeled in SU, and rendered in KS @ 1920x1080. Took a bit under 3 hours on my 2013 i7 iMac. Anyone think Thea can do that? If so, I have a license and can try. My early tests told me no, but then I'm not an accomplished Thea user.
                      http://dl.dropboxusercontent.com/u/3788438/argodesign/hyperloop/Renders/Coach.176.jpg
                        driven
                        that looks very well accomplished to me...
                        I think KS may ignore the 0.0, even though they extract it...
                        heres some code that I've been fiddling with to try and work out the variance...
                              model = Sketchup.active_model
                              camera = model.active_view.camera
                              position = camera.eye.to_a
                              direction = camera.eye.vector_to(camera.target)
                              up = camera.up
                              fov = camera.fov
                              aspect_ratio = camera.aspect_ratio
                              width = model.active_view.vpwidth
                              height = model.active_view.vpheight
                             p [ position, direction.to_a, camera.up.to_a, fov, aspect_ratio, width, height]
                        view = model.active_view
                        target = camera.target
                        vector = target - position
                        if vector.x>0
                          if vector.y>0
                            az = Geom;;Vector3d.new(0,1,0).angle_between(vector).radians
                          else
                            az = Geom;;Vector3d.new(1,0,0).angle_between(vector).radians+Math;;PI/2
                        else
                          if vector.y<0
                            az = Geom;;Vector3d.new(0,-1,0).angle_between(vector).radians+Math;;PI
                          else
                            az = Geom;;Vector3d.new(-1,0,0).angle_between(vector).radians+(3*Math;;PI/2)
                        the first one is just the same as KS pulls out
                        the second bit is trying to see how they arrive at the azimuth...
                        I remember reading some where that SU reads from the camera 'film' plane and you need to subtract the length to the lens 'plane', or similar... [I can't find the link]
                        the API has to much misinformation about all of this...
                        • chippwaltersC
                          chippwalters
                          Thanks for you help. I'll test your new code tomorrow when I get a moment.
                          The workaround I found seems to be doing the trick: Here's a model I built tonight and used a SU wireframe overlaid on top (autonomous mobile office meeting room for an article) and it seems to work pretty well . FWIW, the model is not complete...just WIP).
                          http://dl.dropboxusercontent.com/u/3788438/argodesign/FastCoOfficeOfFuture/OOFRenders/OOF01.192.jpg
                          • reptilesliceR
                            reptileslice
                            Can someone please summarize the working solution to this SKP>KS FOV + focal length 1:1 export dilemma. Super irritated with KS. Thanks for your consideration!
                            • chippwaltersC
                              chippwalters
                              Last I checked, the latest KeyShot plugin seemed to be working.
                              • 2 / 2
