    SketchUp and KeyShot FOV and Focal Length don't match
    31 Posts 4 Posters 7.6k Views 4 Watching
    • chippwaltersC Offline
      chippwalters
      @driven said:
      however, you want to see if this works, without the workaround?
      [attachment=0:3036vr1q]<!-- ia0 -->keyShotExporter.rb<!-- ia0 -->[/attachment:3036vr1q]
      in Ruby Console
      load ~/Downloads/keyShotExporter.rb
      then test a correctly size window export...
      may work...
      Thanks for the help! When I run it I get this:
      Error; #<SyntaxError; <main>; unknown regexp options - kyShtEprtr>
      SketchUp;1;in `eval'
      Currently working with Cross-Reality technologies
        chippwalters
        Yes, I contacted them. They don't really have an answer. They say it works with SU15 but the camera transfer doesn't work right. I was hoping to try and figure out a manual way to go from one setting to the other. I know it's possible to do it manually, I just need to find the right 'formula' and while I posted this same on their forum (and support ticket), I doubt there's much if any answer there.
          driven
          I forgot the quotes ""
          load  "~/Downloads/keyShotExporter.rb"
            chippwalters
            Sorry to be a pain. But now, when I copy/paste it in I receive:
            /Users/chippwalters/Downloads/keyShotExporter.rb;35; warning; already initialized constant KeyShot5;;Set
            /Users/chippwalters/Library/Application Support/SketchUp 2015/SketchUp/Plugins/luxion_keyshot5/keyShotExporter.rb;35; warning; previous definition of Set was here
            /Users/chippwalters/Downloads/keyShotExporter.rb;316; warning; already initialized constant KeyShot5;;TEXTURE_PATH
            /Users/chippwalters/Library/Application Support/SketchUp 2015/SketchUp/Plugins/luxion_keyshot5/keyShotExporter.rb;309; warning; previous definition of TEXTURE_PATH was here
            /Users/chippwalters/Downloads/keyShotExporter.rb;319; warning; already initialized constant KeyShot5;;VERSION
            /Users/chippwalters/Library/Application Support/SketchUp 2015/SketchUp/Plugins/luxion_keyshot5/keyShotExporter.rb;312; warning; previous definition of VERSION was here
            true
            Not sure what to do...
              slbaumgartner
              Those warnings occur when you reload a Ruby that defines constants in its code. They won't happen if the code is written to allow for this possibility. However, in most cases the warnings have no effect and can safely be ignored. The final line saying "true" is your indicator that the load succeeded.
                chippwalters
                So then, what do I do next? Use the Keyshot plugin button to export the file? Will it use your script or it's script?
                  driven
                  steve beat me to it but hi ho...
                  there just warnings, because we overwrite the existing one for the SU session...
                  the advantage of testing this way is it's immediate and if it doesn't work you just trash it...
                  the old one will load again after a restart...
                  if it does work, you can move it to the folder and rename the old one or trash it...
                    driven
                    it will use the last loaded script, i.e. my version...
                      chippwalters
                      Thanks.
                      I did what you said, but the results weren't what was expected:
                      1. ORIGINAL in SU (Focal Lenght 42mm, FOV 46.8 degrees)
                      2. Using your plugin code. Note the FOV is different, but still not correct.
                      3. ORIGINAL KS Plugin. Note the FOV is also different.
                      http://dl.dropboxusercontent.com/u/3788438/3D/cameramapping4.jpg
                        driven
                        you want post the skp [or PM...]
                          chippwalters
                          Here's the SKP
                          https://dl.dropboxusercontent.com/u/3788438/3D/test.skp
                            driven
                            btw, so you know...
                            the only thing I change was a 'back up' for a SU shortfall
                             if cam_aspect == 0.0
                                    cam_aspect = width/height.to_f.round(3)
                            I you don't have a Advanced camera set, SU sets the aspect ratio to 0.0, which is crazy...
                            this bit of code just tell KS to use 16:9 in that circumstance...
                            I'll have a look at your skp...
                              chippwalters
                              @driven said:
                              btw, so you know...
                              >       end
                              Thanks again for your generous help.
                              I did look at your Ruby and saw that, and was wondering if there was anything else. I've written some Python scripts for Vue-Infinite, but don't know much about SU's api-- other than other plugins have figured this out-- and KS hasn't. I believe they first mentioned to me SU didn't have the correct api hooks to get an accurate camera from. That's when I mentioned all the other renderers have figured it out. They said they would take a look at it. Last time they said they'd work on the SU plugin it took them 2 years.
                              Too bad Thea and Vray are so damn slow compared to Keyshot. Of course, they both can do a lot more too!
                              Fwiw, here's an interior shot modeled in SU, and rendered in KS @ 1920x1080. Took a bit under 3 hours on my 2013 i7 iMac. Anyone think Thea can do that? If so, I have a license and can try. My early tests told me no, but then I'm not an accomplished Thea user.
                              http://dl.dropboxusercontent.com/u/3788438/argodesign/hyperloop/Renders/Coach.176.jpg
                                driven
                                that looks very well accomplished to me...
                                I think KS may ignore the 0.0, even though they extract it...
                                heres some code that I've been fiddling with to try and work out the variance...
                                      model = Sketchup.active_model
                                      camera = model.active_view.camera
                                      position = camera.eye.to_a
                                      direction = camera.eye.vector_to(camera.target)
                                      up = camera.up
                                      fov = camera.fov
                                      aspect_ratio = camera.aspect_ratio
                                      width = model.active_view.vpwidth
                                      height = model.active_view.vpheight
                                     p [ position, direction.to_a, camera.up.to_a, fov, aspect_ratio, width, height]
                                view = model.active_view
                                target = camera.target
                                vector = target - position
                                if vector.x>0
                                  if vector.y>0
                                    az = Geom;;Vector3d.new(0,1,0).angle_between(vector).radians
                                  else
                                    az = Geom;;Vector3d.new(1,0,0).angle_between(vector).radians+Math;;PI/2
                                else
                                  if vector.y<0
                                    az = Geom;;Vector3d.new(0,-1,0).angle_between(vector).radians+Math;;PI
                                  else
                                    az = Geom;;Vector3d.new(-1,0,0).angle_between(vector).radians+(3*Math;;PI/2)
                                the first one is just the same as KS pulls out
                                the second bit is trying to see how they arrive at the azimuth...
                                I remember reading some where that SU reads from the camera 'film' plane and you need to subtract the length to the lens 'plane', or similar... [I can't find the link]
                                the API has to much misinformation about all of this...
                                  chippwalters
                                  Thanks for you help. I'll test your new code tomorrow when I get a moment.
                                  The workaround I found seems to be doing the trick: Here's a model I built tonight and used a SU wireframe overlaid on top (autonomous mobile office meeting room for an article) and it seems to work pretty well . FWIW, the model is not complete...just WIP).
                                  http://dl.dropboxusercontent.com/u/3788438/argodesign/FastCoOfficeOfFuture/OOFRenders/OOF01.192.jpg
                                  • reptilesliceR Offline
                                    reptileslice
                                    Can someone please summarize the working solution to this SKP>KS FOV + focal length 1:1 export dilemma. Super irritated with KS. Thanks for your consideration!
                                      chippwalters
                                      Last I checked, the latest KeyShot plugin seemed to be working.
                                      • 2 / 2
