    Get the coordinates of the corners of the viewport
    31 Posts 6 Posters 4.5k Views 6 Watching
      driven
      if you 'really' want to and it's for v14/5 then you may be able to do something I do on a mac...
      for mac I use a bin tool, but there is a windows gem called 'auto-click', that has get/set mouse position methods.
      basic concept is from inside a tool you
      programmatically double-click at [vpwidth/2, vpheight/2] e.g. a = [600,400]
      retrieve the SU x,y with onLButtonDoubleClick(flags, x, y, view) e.g. b = [458,340]
      then offset = a-b i.e. top left corner of viewport...
      I've used it for automating 'user input' tests, mainly for the fun of it...
        Anton_S
        Hello dacastror.
        There is no SketchUp API function that will give you the upper left corner of the viewport area, relative to screen origin. However, one can use Windows API to get it, for the Windows OS only.
        FYI, I wrote a plugin, called SU windows settings, and it too creates a webdialog, hides all borders and places it in any corner user clips it to. You can see that plugin here: http://sketchucation.com/forums/viewtopic.php?t=42926
        When I get home, I'll provide some code snippet of getting screen coordinates to viewport origin.
        Anton
          dacastror
          thank you very much for your answers, I really want to do this, Driven interesting that behavior in Mac, I try to do something with it.
          Anton thank you very much, I was just beginning to explore your code is really awesome 😛, I can see that the coordinates of the viewport are obtained with this AMS::Sketchup::Viewport.rect returns an array like this [74, 120, 1678, 991] that corresponds to what I need 😛. Although I feel like killing a fly using an atomic bomb, it would be excessive to require the complete library, I'm trying to study their code to accomplish what I need through Win32API, but it is proving difficult. Nevertheless, I can contemplate the beauty and power of your code
          (google translator)
            driven
            what version of SU are you running?
            the gem I mentioned should work with Ruby 2 and can be installed in SU v14/v15 using
            Gem.install('auto_click')
            GitHub - erinata/auto_click: Provide several Ruby methods for simulating mouse click, cursor movement and keystrokes in Windows. This gem use DL library and SendInput method so there is no dependency on FFI, AutoIt or Win32-api. (More control over mouse movement such as speed or locus will be implemented in future releases)
            Provide several Ruby methods for simulating mouse click, cursor movement and keystrokes in Windows. This gem use DL library and SendInput method so there is no dependency on FFI, AutoIt or Win32-api. (More control over mouse movement such as speed or locus will be implemented in future releases) - erinata/auto_click
            GitHub (github.com)
            good luck
              dacastror
              Driven thanks, I'll look it looks interesting, I wonder if there will be a gem that allows some things like making Win32API so that they can perform on Mac
              Anton would perform similar to yours definitions, but using Win32API
              this is your original definition
                  def client_rect(hwnd, mode = 1)
                    return nil unless valid?(hwnd)
                    mode = mode.to_i
                    mode = 1 unless mode.between?(1,3)
                    lpRect = 0.chr*16
                    wins;;GetClientRect.call(hwnd, lpRect)
                    crect = lpRect.unpack('l*')
                    return crect if mode == 3
                    style = wins;;GetWindowLong.call(hwnd, -16)
                    exstyle = wins;;GetWindowLong.call(hwnd, -20)
                    wins;;AdjustWindowRectEx.call(lpRect, style, false, exstyle)
                    arect = lpRect.unpack('l*')
                    r = []
                    if mode == 1
                      wins;;GetWindowRect.call(hwnd, lpRect)
                      r[0] = rect[0] - arect[0]
                      r[1] = rect[1] - arect[1]
                      r[2] = r[0] + crect[2]
                      r[3] = r[1] + crect[3]
                    else
                      r[0] = -arect[0]
                      r[1] = -arect[1]
                    r
              and this is what I try to do, I do not know if it is correct
              require "Win32API"
              GetClientRect = Win32API.new( 'user32.dll','GetClientRect', 'LP', 'B')
              GetWindowLong = Win32API.new("user32.dll" , "GetWindowLong", "LI" , "L")
              AdjustWindowRectEx = Win32API.new('user32.dll','AdjustWindowRectEx', 'PLBL', 'B')
              GetWindowRect = Win32API.new('user32.dll','GetWindowRect', 'LP', 'B')
                mode = mode.to_i
                lpRect = 0.chr*16
                style = GetWindowLong.call(hwnd, -16)
                exstyle = GetWindowLong.call(hwnd, -20)
                AdjustWindowRectEx.call(lpRect, style, exstyle)
                r = []
                if mode == 1
                else
                  r[0] = -arect[0]
                  r[1] = -arect[1]
                 r
              at this time I do not know how to get "hwnd" for sketchup window
              (google translator)
                Anton_S
                Decastor, there are several ways of getting SU window. My way, which is used in my C++ extension of AMS library, uses callbacks to iterate through all windows and find the one that matches SU window properties, like window class name and SU process id. Win32API doesn't support callbacks, so you'll need a simpler way of getting handle to SU window. A simple way of getting SU window is by calling GetActiveWindow when SU starts. It should that way, in most cases (probably in all), return handle to SU window. Then, you will also need a handle to the viewport child window. You're trying to acquire rectangle of viewport window after all. I will provide you a full proper working function in a day or so.
                  dacastror
                  wow! thank you very much Anton, get this Handle seems more sophisticated than I expected
                  I'm anxious to see how to do 😄
                  • Dan RathbunD
                    Dan Rathbun
                    Just as a heads up, Win32API has been deprecated (for some time,) and in Ruby 1.9, was removed, and replaced with a "Win32API.rb" that is a wrapper making calls using the DL library.
                    So since then, you'd actually be using DL, when you made Win32API calls.
                    However DL has recently been deprecated, in favor of the Fiddle library.
                    In Ruby 2.0, there is a conditional loader that will attempt to wrap DL as calls into Fiddle.
                    Be warned that DL has already been removed from Ruby 2.2 !
                    Time to start learning Fiddle.
                    I'm not here much anymore.
                      Anton_S
                      Well, in that deprecation purpose, I think the most convenient approach would be to write a c extension. But, meanwhile I will provide a Win32API reliant version, and then a C extension if decastror wishes.
                        Anton_S
                        Here it is decastror!
                        # Load Win32API
                        dir = File.dirname(__FILE__)
                        if RUBY_VERSION =~ /2.0/
                          # Standard libraries included in SU 2014+.
                          require 'Win32API'
                        else
                          # Bundled with plugin for SU 2013 and prior.
                          require File.join(dir, 'Win32API')
                        # Top level namespace just for convinience.
                        module Decastror; end
                        # Sub namespace for particular plugin.
                        # It can also go directly into your top level namespace.
                        module Decastror;;MyTool
                          # Import some Windows API functions
                          GetActiveWindow       = Win32API.new('User32', 'GetActiveWindow', '', 'L')
                          GetWindow             = Win32API.new('User32', 'GetWindow', 'LL', 'L')
                          GetWindowRect         = Win32API.new('User32', 'GetWindowRect', 'LP', 'I')
                          GetClientRect         = Win32API.new('User32', 'GetClientRect', 'LP', 'I')
                          FindWindowEx          = Win32API.new('User32', 'FindWindowEx', 'LLPP', 'L')
                          GetWindowLong         = Win32API.new('User32', 'GetWindowLong', 'LI', 'L')
                          AdjustWindowRectEx    = Win32API.new('User32', 'AdjustWindowRectEx', 'PLIL', 'I')
                          # This simple technique works in most cases if not all.
                          active = GetActiveWindow.call()
                          owner = GetWindow.call(active, 4)
                          MAIN_HWND = owner == 0 ? active ; owner
                          class << self
                            # Get handle to viewport window.
                            # The reason we need this function, rather than constant is because viewport
                            # handle is not constant. Viewport handle changes as view preferences
                            # change.
                            # @return [Fixnum]
                            def get_viewport_handle
                              # View class name is different among different SU versions.
                              # SU6 uses AfxFrameOrView70u
                              # SU7 and SU8 use AfxFrameOrView80u
                              # SU2013 through SU2015 use AfxFrameOrView100u
                              cname = case Sketchup.version.to_i
                                when 6
                                  'AfxFrameOrView70u'
                                when 7,8
                                  'AfxFrameOrView80u'
                                else
                                  'AfxFrameOrView100u'
                              return FindWindowEx.call(MAIN_HWND, 0, cname, nil)
                            # Get screen coordinates to the upper-left and lower-right corners of the
                            # viewport window.
                            # @return [Array<Fixnum>] [x1,y1, x2,y2]
                            def get_viewport_rect
                              viewport = get_viewport_handle()
                              style = GetWindowLong.call(viewport, -16)
                              ex_style = GetWindowLong.call(viewport, -20)
                              wrect = [0,0,0,0].pack('l*')
                              crect = [0,0,0,0].pack('l*')
                              arect = [0,0,0,0].pack('l*')
                              GetWindowRect.call(viewport, wrect)
                              GetClientRect.call(viewport, crect)
                              GetClientRect.call(viewport, arect)
                              AdjustWindowRectEx.call(arect, style, 0, ex_style)
                              wrect = wrect.unpack('l*')
                              crect = crect.unpack('l*')
                              arect = arect.unpack('l*')
                              return [
                                wrect[0] - arect[0],
                                wrect[1] - arect[1],
                                wrect[0] - arect[0] + crect[2],
                                wrect[1] - arect[1] + crect[3]
                          end # proxy class
                        end # module Decastror;;MyTool
                        unless file_loaded?(__FILE__)
                          # This field is added just in case file is loaded more than once.
                          # Add some menus and stuff that should be instantiated only once.
                          file_loaded(__FILE__)
                        To get viewport rect:
                        r = Decastror::MyTool.get_viewport_rect
                        And this will give you viewport origin:
                        origin = [r[0], r[1]]
                        This will get viewport size:
                        size = [r[2]-r[0], r[3]-r[1]]
                        I created a sample tool. You can customize it to your taste and work your extension from there.
                        decastror_tool.zip
                          dacastror
                          ☀ 😍 🤢 It works perfectly, Anton am very grateful that you've taken the time to write this, it's very good.
                          I'm studying your code to see how does its magic, I have a question about owner = GetWindow.call (active, 4) I do not quite know who does this
                          Other than that, I only see a bug in the code, you wrote D ecastror instead of Dacastror
                          😆 I'm kidding of course.
                          Build my first extension in C would be wonderful, it would be a good opportunity to dust off my little knowledge of C and most interestingly, could look to the development of faster plugins,
                          once, I tried perform the "hello world" with a guide published on GitHub, but I got lost on the way, I do not remember why, I would very much accomplish, Anton that would be awesome.
                          thank you very much for the advice Dan. I'll read about that library.
                          (translated with google translator)
                            dacastror
                            I'm realizing I have to create a kind of observer of the size and position of the viewport, so that my webdialog is maintained in the corner when the user changes the size or position of the window Sketchup, for now the only option I see is do something with UI.start_timer and UI.stop_timer
                              driven
                              simple question,...
                              what do you want to 'put' in the webdialog?
                              adding observers has a cost to performance and can be very hard to debug when they go wrong...
                              just curious...
                                Anton_S
                                The code has two parts to it:
                                active = GetActiveWindow.call() owner = GetWindow.call(active, 4) MAIN_HWND = owner == 0 ? active : owner
                                When SU starts, we get active window. The active window could return a handle to SU window or a handle to a webdialog belonging to SU window. To make sure that we get SU window, and not a webdialog, we use the GetWindow with a GW_OWNER command.
                                Yes, a timer would be an easy way to go. However, my AMS Library, has such observers (EDIT: But, they don't rely on timer. They rely on actual messages coming from SU window procedure). You can see documentation here, in case you are interested: AMS::SketchupObserver.#swo_on_size_move
                                  dacastror
                                  Anton thank you very much for your explanation and links.
                                  you have many observers available it is awesome, I have two versions of your library,1.0.9 and 2.2.0, I'm trying to understand how you manage to observe changes in the windows but I can not understand how you do, What is the basis of your observers? Is it a timer that question every so often? or does it work differently? Anton sorry for asking so much, It is that I am interested in the mechanisms behind the clock.
                                  I want to keep as a surprise, when I finish you will understand why I needed this, however I will seriously consider your points.
                                    dacastror
                                    I want to keep as a surprise, When I finish you will understand why I needed this, however I will seriously Consider Your points.
                                    it seems that is no longer available the info in this link
                                    We're sorry, the page you requested cannot be found.
                                    you could give me another clue to study this?
                                      Anton_S
                                      Here is window procedure I'm using to monitor window events: [Window Procedure](https://msdn.microsoft.com/en-us/library/windows/desktop/ms633573(v)
                                      Here is more info about window procedures and how to use them: https://msdn.microsoft.com/en-us/library/windows/desktop/ms632593(v=vs.85).aspx
                                        Anton_S
                                        My observers work by intersecting into SU window procedure and monitoring its messages. That is, too, possible with Windows API. No timers are needed. I have it all integrated in my C++ extension of AMS Library. You can read here about window procedure: https://msdn.microsoft.com/en-us/library/windows/desktop/ms633573(v=vs.85).aspx
                                          dacastror
                                          Anton thank you very much, I'll get to study this 🤓
                                            Anton_S
                                            Your welcome, dacastror. Window Procedure is a callback function. Win32API has no feature to create callbacks. You could use Ruby Fiddle (available as standard lib in SU2014+) or Win32-API (A more advanced win32 API by Daniel J Berger), but they could endup very performance consuming if you try to monitor SU WindowProc through Ruby. You might want to consider writing a C/C++ extension.
                                            Hey, I will make a little C++ extension for you as you mentioned your not very familiar with C and how to use it in SU. All you'll need is Visual Studio (VS2010 preferred).
