    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 231.7k Views 85 Watching
    • N
      nmhai
      error for me. i install: richsection and dibac(solid section).
      win8.1 x64 sketchup 2015
      • K
        kylintz
        The new plugin crash when I use rich section on sketchup without texture.
        And it only create 1 scene for each section now, unlike the version before this where I got 2 scenes for each rich section. I tried to search on the rich section setting on the "scene created for each rich section", there's only one option available "scene, section plane visible, no camera aplies."
        I tried to reset the setting with no results. I can't get 2 scenes for each rich section that I create. I missed that auto paralel camera and auto hide section plane visibility whenever I create rich section.
          agmgpro
          where can I find the older version (0.5.4)? In this latest version there's no option in "settings" to create 2 scenes...??? It's crashing a lot too. Installed on SKU2015 Pro. Version 0.5.4 was working just fine, and the option for creating 2 scenes (without camera + aligned to section), is very important for us! Please help! Appreciate your attention, Gabriel
          • K
            kylintz
            I have the same problem like you agmgpro haha
            • P
              pgarmyn
              You can create as much scenes as you want, but, after scene creation, you will have to switch the section layer on, set section plan visibility ... and update the scene. 2 Scenes (in the settings) will come back, but i can't make 0.5.4 available because the data structure (for richsection information) saved in your file has changed.
              About crashing : what other plugins are you using?
              • K
                kylintz
                I think the crashing is caused by the #default material. On a fresh sketchup file, if i create a scene without applying #default rich section material to random object first, the sketchup would crash after creating rich section.
                And about the 2 scenes, I couldn't get it work. I couldn't make the option to create 2 scenes automaticaly for each rich section to work. There's only one option available on rich section setting for "Scenes created for each richsection" : Scene, sectionplan visible, no camera applied.
                • P
                  pgarmyn
                  @kylintz:
                  Maybee my answer was not clear : the option for creation of 2 scenes doesn't exist in the latest version (it will come back). You can create yourself extra scenes as described before.
                  About problems with loading #default : is the plugin installed in the default folder?
                  To be able to help you, i need :
                  If you switch on the ruby console : are there errors ?
                  Please fill in your profile : windows version, Sketchup version ...
                  • E
                    Esense3d
                    Hello
                    Itmakes sektions without Material ?
                    Win 7 su 2015
                    Thank you
                    • P
                      pgarmyn
                      @esense3d:
                      Did you tried without changing the parameters?
                        agmgpro
                        Thanks pgarmyn,
                        waiting then for 2 scenes to come back!
                        (it's possible for you to send me the older version via email??? If yes, my email is agmgpro@gmail.com)
                        Thanks again!
                        • B
                          bik
                          I have a problem with the setting panel.
                          When I click on the button to call the setting panel, nothing happens.
                          (My Sketchup is the last one 15.3.331 64 bit)
                          And most of time I encounter a bug splat windows when I just click on "create" for a first Rich Section. The section become grey, and everything close.
                          An other information for you : When I succeed to create one, I don't have a lot of color section choice, only wide stripes by default and Black (plain color)...
                          I don't understand why I'm alone to have this problem.
                          I use sketchup for a professional need and I'm aware about how the sketchup plugins works.
                          I have tried to remove your plugin, and install again... But it's the same problem all the time.
                          If any conflicts, just look below. My only plugins installed are :
                          Sketchucation
                          Bezierspline
                          ExtrudeTools
                          PipeAlongPath
                          tt_cleanup
                          tt_material_replacer
                          Projection
                          jf_addlayer
                          Fredo6_RoundCorner
                          Mirror
                          If any idea ?
                          • P
                            pgarmyn
                            @bik said:
                            1. I have a problem with the setting panel.
                            2. And most of time I encounter a bug splat windows when I just click on "create" for a first Rich Section. The section become grey, and everything close.
                            3. When I succeed to create one, I don't have a lot of color section choice, only wide stripes by default and Black (plain color)...
                            1. You have to select a section plan or section group. The instructions are in the text field below, or read the pdf file in the first post.
                            2. How big is your mode? Start without projection. For big projects, it is better to limit projection : with layers from scene, limited by distance... . Do not select any command after selecting the ´creaté button, until the Section panel is updated.
                            3. Only one default material will be created and aplied after creation with the default settings. Please Read the instructions : pdf file included in the first post: http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=55072#p499865
                            • shake1S
                              shake1
                              Hi, this is a little bug
                              win7/64
                              Su 2015 3.331 x64
                              • srxS
                                srx
                                Today I found out that plugin has time limit. How to continue using it?
                                www.saurus.rs
                                  agmgpro
                                  The same thing is happening with me... please help!
                                  • P
                                    Petrroo
                                    Hi! Thank you so much for your work on this plugin. A very useful program.
                                    But at the moment really need Your help!
                                    Already addressed, but the message remained unanswered! Suddenly stopped working plugin RichSection. As I understand the network is a demo version that stops working after a certain period. Work on the Mac. Previously had no problems. And all of a sudden stopped working. Tried to reinstall - no help. The most interesting thing that is worth Parallels with the sketch for the Windows. Put the plugin in there - the same nonsense - lets not create a section. Open the file with a previously created sections RichSection - they are edited, but all are not created equal! Really need Your help, because the whole model was done with the expectation of making further using this plugin!!! Thank you!
                                    • G
                                      Gliph
                                      Le plug-in ne fonctionne plus, apparement la version demo s'arrête au 2 juillet 2015. On paye où pour la "full version" ? 😮
                                      • romboutR
                                        rombout
                                        Im trying this again on mac su make 2015, but nothing happens? is this a know issue, i did a quick search here but coulnt find any mac users...
                                        i think i found the issue, its a license thing. Thought this one was for free 😄
                                        RichSection: Time-limited FULL WORKING license
                                        Expired at 2015-07-01 20:00:00 -0400 : [nil]
                                        • cucsat2003C
                                          cucsat2003
                                          @ pgarmyn:Sorry for a dumb question.
                                          But I've installed RS plugin,and it's icons appeared,but I can't add rich section(first icon) anymore.When I hit the icon,there's no section appears like in your video.
                                          I've read all comments in this topic but can't find solution.
                                          Should you help me please?
                                          This plugin seems so great and I can't wait to try it.
                                            Dimitri972
                                            I fixed time expired problem. Here it is:
                                            http://www.mediafire.com/download/brjzmnqzbcv38fp/RichSectionv0.5.8FULLByDimitri.zip
                                            Author was't answering question for months. I tried to fixing expired issue and fixed. If this isn't wanting thing in this forum, you can delete my post. I don't know forum rules.
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 18 / 20
