Shetchup Make 2015
Hi everybody :
After downloading Setup.exe for Sketchup Make 2015, I got the error message referring to meeting the requirement of having Windows 7 or later..... Currently, I've got Windows 7 Professional / 32-bit. I'm not sure what other requirements I would have to meet. garystan -
Make sure you download and install Sketchup 32 bit. The 64 bit version is not working on Windows 7 32 bit. "You can install either 32-bit or 64-bit on a 64-bit version of Windows; if you’re using a 32-bit version of Windows, you may only install the 32-bit version of SketchUp." http://help.sketchup.com/en/article/3000069
Yep. It sounds like you downloaded the wrong version. The 32-bit version will help.
